Old 21-12-08, 10:01 PM   #1
Mark_h
Mark_h's Avatar
Default Valve clearance checking.
I assume the answer is no, but before I go making a right old mess on the drive-way, do you have to drain the engine oil before checking the valve clearances? Head covers off, dynamo plug out and viewing hole plug out. Any of those below the natural oil level and full of oil? K3 SV1000 if it makes any difference.
Cheers,
Mark
Minister for Sustainability
Old 21-12-08, 10:12 PM   #2
Wideboy
Evel Knievel
Wideboy's Avatar
Default Re: Valve clearance checking.
i didnt on mine HTH
05 DRZ400E
RIP hovis
Old 21-12-08, 10:19 PM   #3
injury_ian
Nor mine.
All the oil should be located in the sump...
Old 22-12-08, 01:01 AM   #4
No you do not have to drop the oil
Old 22-12-08, 02:36 AM   #5
Only if you choose to do it upside down.
Old 22-12-08, 08:12 AM   #6
injury_ian
Or whilst it is running?
Old 22-12-08, 08:31 AM   #7
All of the above true, just like to add how easy it is to adjust SV1000 clearances as you don't don't need to disturb the camchain to do it, a lovely and most welcome bit of design.
Just ensure the decompressors don't interfere with your measurements.
Valve Clearance Readings Mr_Chin SV Talk, Tuning & Tweaking 2 22-12-08 08:54 AM
Valve Clearance Tight stnd SV Talk, Tuning & Tweaking 2 02-09-08 10:52 PM
A question of valve clearance... BillyC SV Talk, Tuning & Tweaking 11 23-11-05 12:36 AM
15k service - valve clearance The Mass SV Talk, Tuning & Tweaking 21 18-08-05 09:41 AM
Valve Clearance Craig SV Talk, Tuning & Tweaking 3 14-02-05 07:34 PM
