Old 23-02-19, 07:46 AM   #1
Othen
Default K6 Oil Cooler and Oil Pipe
I've just swapped the oil lines on my K6 for an aftermarket kit, only the long line had failed, I took the opportunity to fit another oil cooler I'd previously cleaned up at the same time. These bits are left over and and free to a good home should anyone need them:
Oil cooler: needs a clean up but worked fine on the bike before the swap. The small bracket at the bottom that the protective mesh screws on has fallen off.
Short oil line: this also worked fine, according to the bike's service records this is a newer part.
These are free if anyone wants to collect them (NN18 ).
£0.00
Alan
Oil cooler pipe leak? rockchunk SV Talk, Tuning & Tweaking 11 12-05-14 07:40 PM
Right Hand Oil Cooler pipe joethebrave Stuff Wanted 0 18-02-14 08:22 PM
Oil Cooler Pipe Elliott Stuff Wanted 3 22-12-13 05:59 PM
K3 Oil Cooler Pipe Advice larssonn Stuff Wanted 1 07-01-12 04:30 PM
K3-K8 RH oil cooler pipe DavieSV Stuff Wanted 6 10-08-10 08:46 AM
