Old 26-10-17, 07:16 PM   #21
R1ffR4ff
R1ffR4ff's Avatar
Default Re: Battery voltages
That's good news.Did and clean the Large multi-connector pins and sockets between the R/R and Stator?Any corrosion should be removed.R/R units are a very robust device and under normal conditions can last many years.
I have some that are over 35 years old and still working however it's the Multi-connector and corrosion there that causes the most failures in them.
Old 26-10-17, 07:22 PM   #22
Chris_SVS
Chris_SVS's Avatar
Yep given a clean(didn't need much), all good now
I've also became a master of fiddly jobs, never had the tank off once :P
Chris_SVS is offline   Reply With Quote
Old 26-10-17, 07:25 PM   #23
R1ffR4ff
R1ffR4ff's Avatar
Originally Posted by Chris_SVS View Post
Yep given a clean, all good now
Nice one
Mine are treated with ACF50 and any time I need to access the rear fairing I'll check and clean it again and or next Spring as part of my,"Pre-Season" servicing where I go through the electrics as well as everything else that's needed.
Old 26-10-17, 07:30 PM   #24
Chris_SVS
Chris_SVS's Avatar
Added to my mental list of jobs to do If we get a spell of icy weather, my commute isn't rideable so I can take the time to get stuck into neglected stuff. Throttle body assy looks a bit manky but functional, oil cooler and hoses could do with a freshen up kinda stuff
Old 26-10-17, 07:31 PM   #25
R1ffR4ff
R1ffR4ff's Avatar
ACF50 is great on hoses.Keeps them from decaying and is great on the clamps as well
Old 26-10-17, 07:34 PM   #26
Chris_SVS
Chris_SVS's Avatar
All part of the master plan my good man :P
Old 26-10-17, 07:45 PM   #27
R1ffR4ff
R1ffR4ff's Avatar
Wrong post
Old 26-10-17, 08:14 PM   #28
i found something that ACF-50 does not like... latex. i wrapped a connector in a latex glove with some acf50 and it turned the glove into jelly within a week.
Can a loose battery terminal prevent the battery from charging while being able to crank the engine? maxinc Bikes - Talk & Issues 5 22-07-11 02:59 PM
dead battery - possible reg/rec + battery? collis SV Talk, Tuning & Tweaking 8 20-09-10 02:47 PM
Optimate battery charger drains the battery flymo Bikes - Talk & Issues 10 10-06-09 10:41 AM
Battery/Starting problem - new battery hasnt fixed it! Aaron SV Talk, Tuning & Tweaking 13 24-01-05 05:21 PM
