Old 16-05-07, 02:31 PM   #1
John 675
Post Cutting out when clutch pulled in
Sometimes, mainly in the morning the machine will cut out when i pull in the clutch? its started happening since i put my open can on, i know its been commented on before but i couldnt find thread, it only happens when my clutch is in and A: i blip the throttle B: i hold the clutch in for about 7 secs ( roughly ). i thought it might also be a tempreture thing but it happend at about 68 degrees before
i have to do a rolling start when it does it, scary stuff.
any help would be great,
Old 16-05-07, 02:46 PM   #2
Alastair
Default Re: Cutting out when clutch pulled in
I know next to nothing about bike mechanics but surely it's the idle speed that needs upping a tiny bit. Have you tried that?
Old 16-05-07, 02:53 PM   #3
John 675
did think of that but i thought with it being intermitant then it wouldnt do the job, also it sits at idle fine when i start it in the morning ??
one thing i did think was could my new open can cause my revs to drop lower than idle when i blip the throttle or pull the clutch in???
Old 16-05-07, 02:57 PM   #4
jambo
jambo's Avatar
check the sidestand switch?
Old 16-05-07, 02:58 PM   #5
Alastair
The auto choke would be on after starting up though right? That raises the revs. I don't know why but it sounds like the can has affected the idle speed.
My old 125 would idle fine when stopping but cut out after a few seconds of sitting still. Raising the idle speed by like 200rpm sorted it right out. I've no idea how FI bikes will work in that respect though.
My K3 occasionally cuts out when blipping or pulling in the clutch before it's fully up to temp too and that's still on a standard can.
Old 16-05-07, 03:07 PM   #6
Baph
I find that my scorpion now & again affects the bike on startup (or at least I'm putting it down to the scorpion). Sometimes it'll start, run for a few seconds, then shut down.
The last time it did this I got out of the car park, a short way up the road to the traffic lights, and bingo. At least the lights were on red.
When I say now & again I mean maybe 1 out of 50ish starts in the cold.
Clutch & side stand switches OK?
Old 16-05-07, 03:15 PM   #7
hovis
i think its just because its cold?
Old 16-05-07, 04:06 PM   #8
Baph
You're confusing carbs with FI there hovis.
In the cold (in the snow in fact), before I fitted the scorpion, I could simply pull the clutch, hit the starter, and bingo, running without any worry of it stalling again.
Old 16-05-07, 06:23 PM   #9
DoubleD
you go to bingo
back on topic - maybe check the clutch & side stand switches are ok.
Old 16-05-07, 06:51 PM   #10
John 675
I checked and they seem fine, it really seems to be a rev issue, because like i said if i blip the throttle the needle drops really low then comes back up to idle speed, about 1500. RPM
Clutch Problem? Cutting off when releasing clutch in first gear! puthsardarade SV Talk, Tuning & Tweaking 15 09-01-08 09:42 PM
Cut out when clutch pulled in andyb SV Talk, Tuning & Tweaking 11 06-03-07 01:19 PM
Engine tone changes when clutch is pulled/released rich_r Bikes - Talk & Issues 12 14-11-06 08:58 PM
Pulled again :( Baph Bikes - Talk & Issues 17 10-11-06 09:22 PM
Pulled Over, WHY ? bbanna South & West Surfers 1 08-01-70 06:58 PM
