Old 08-02-19, 09:42 PM   #5991
Kenzie
Kenzie's Avatar
Someone just remind me about filters. If I have a +1 filter fitted does it mean I need one more stop of light? Say meter reads f5.6 at 1/125, does that mean I step to f4 1/125 or f5.6 at 1/60? Or whatever combination.
Old 08-02-19, 09:43 PM   #5992
yokohama
Cheers Johnny. I'll try it and see what happens. It's a simple enough camera to take apart and clean up if things go wrong.
Old 08-02-19, 09:56 PM   #5993
yokohama
I'm not sure how that works. Do they add a stop upwards - or downwards?
Would you be using it for lens protection or for effect?
An idea might be to put it on a lens and try out a few combinations with your digital camera if possible so you can figure out what it does.
Old 09-02-19, 09:28 AM   #5994
Kenzie
Kenzie's Avatar
It's a yellow filter and I might have meant -1. Supposed to boost contrast in black and white.
Old 09-02-19, 03:32 PM   #5995
yokohama
If it's on a camera with TTL metering, won't it compensate automatically?
I lubed the Fed and put it back together. Seems quite smooth now. The Industar 26 is in bits while I dig hardened 60 year old grease out.
Old 09-02-19, 06:22 PM   #5996
Kenzie
Kenzie's Avatar
No, Kiev 4. Didn't get round to using it today. I did win a new camera though, its compact and slips easily into my pocket.
Sent from my Xperia using Tapatalk
Old 09-02-19, 10:26 PM   #5997
yokohama
What's the new one?
With the filter, I suppose it will darken the image so to compensate, a stop more exposure is needed. I think what you said yesterday sounds right.
The fed and lens are done. It needs a film and testing out.
Old 09-02-19, 11:10 PM   #5998
johnnyrod
johnnyrod's Avatar
Yep the "filter factor" tells you how many stops you need to add to the exposure. You can use a lot of different coloured filters with mono, red will give you really dark skies for example, yellow is the de facto for good contrast. A coloured filter also means any aberrations in the lens are negated as you're only focusing a small range of wavelengths, which is much easier for any lens than a whole spectrum.
Old 09-02-19, 11:33 PM   #5999
Kenzie
Kenzie's Avatar
Just a toy one from the arcade 2p machine.
Old 15-02-19, 09:03 PM   #6000
johnnyrod
johnnyrod's Avatar
Getting pretty quiet in here! What are you all up to? For me, not much, busy at work and been chasing after a new (old) mountain bike which I finally snagged. Still got rolls in the Konica RF and Pentax SLR.
