01-06-19, 02:13 PM | #1 |
Junior Member
Curvy Exhaust - which flavour of stainless is it?
I've taken the exhaust off my 2000 curvy today with the intention of refitting it properly. The can is therefore well and truly open, and there is no chance I'll get all the wriggly things back in.
Here are the problems: Whoever fitted the Viper can has cut too much off the original pipe - so that was leaking. I think as a result of the above, the whole pipe has been badly stressed and the front downpipe has cracked where it joins the Y section. I have enough offcuts of stainless pipe lying around the place to be able to braze it back together with various repair sections - hence the question. I don't want to make it worse by using the wrong flux / rod. Or - shall I buy one from a breaker and fit that? Or - shall I just chuck it all in the scrap bin and buy a complete new one. Clearly thats not my preferred option on financial grounds. Any suggestions gratefully received. |
02-06-19, 09:53 AM | #2 |
Re: Curvy Exhaust - which flavour of stainless is it?
First I'd take and post some pictures.This will help people see better and hopefully give better answers.
If you need a free Picture host I use Imgur, https://imgur.com
02-06-19, 04:43 PM | #3 |
Junior Member
Thats fair - here are some pictures.
Terminal or not? https://app.box.com/s/osfj703pol19gczvrepzc5x81j81ez52 When I said cracked I meant properly cracked. Here's a shot of the link pipe so you can see how little there is to go inside it: https://app.box.com/s/apagidyileofz1u0qddi8nx0opurd5k1 And here's the bit that would connect to the front header pipe - if it weren't in such a mess: https://app.box.com/s/52vmoe9l8aezk6o2w83s222l9xg8qj73 Cheers. |
02-06-19, 05:46 PM | #4 | |
I’d say that is beyond sensible repair. I think finding a good used original system would be the way to go - I should think £60-£80 would be a good target price. This looks perfectly serviceable and would clean up with an hour’s work: https://rover.ebay.com/rover/0/0/0?m...2F113701331975 ... I think that would work out cheaper in the long term than a repair. Sent from my iPad using Tapatalk Last edited by Othen; 02-06-19 at 05:58 PM. |
02-06-19, 06:27 PM | #5 | |
02-06-19, 07:10 PM | #6 |
Junior Member
I think you're both right.
Does anyone know if a later exhaust will fit a curvy - obviously with a blanking plug for the lambda? For obvious reasons I'd prefer a younger one. Thanks again. |
02-06-19, 07:40 PM | #7 |
There might be something on here,
https://www.partshark.co.uk/motorbik...zuki/sv%2B650/ Put exhaust in the Search box and... There are a few Motorcycle breakers on-line so keep searching.
"Stultus est sicut stultus facit" Last edited by R1ffR4ff; 02-06-19 at 07:41 PM. |
04-06-19, 07:13 PM | #8 | |
Did you mean would a pointy exhaust fit a curvy? I don’t know the answer for sure, but at first sight I’d say I doubt it. Someone much more knowledgeable than me will correct me if I’m not right. Sent from my iPad using Tapatalk |
04-06-19, 07:24 PM | #9 |
I think pointy to curvey is fine. Think the other way round won't work because of the oil cooler space at first glance.
I'm sure others might chime in. |
21-06-19, 07:54 PM | #10 |
Stainless exhaust pipes for K8? | perry | SV Talk, Tuning & Tweaking | 1 | 07-03-13 04:53 PM |
MTC stainless steel exhaust | doofus4000 | For Sale - SV's and SV related items | 4 | 10-02-13 03:33 PM |
FS: curvy rear stainless steel exhaust hanger | pookie | For Sale - SV's and SV related items | 3 | 13-07-10 08:18 PM |
FUEL Stainless slip-on exhaust for a curvy | martianskippy | For Sale - SV's and SV related items | 16 | 07-03-09 11:24 PM |
Stainless exhaust clamp ? | oldjack | SV Talk, Tuning & Tweaking | 2 | 27-02-07 10:55 PM |
