Old 03-06-19, 05:57 PM   #1
2000curvy
Default Fuel Tank Range
Evening All, my curvy is now finally up and running -hurrah! And thanks to you all for your help and advice.
I replaced the fuel level sensor on it as the old one had fallen into pieces. I bought one off EBay which looked complete. My concern is whether it is working ok. I've filled the tank up, but would appreciate any advice on how many miles I should expect to do before the fuel light will come on? I don't want to assume there is sufficient fuel in the tank as the light hasn't come on! Regards Nick
2000curvy is offline   Reply With Quote
Old 03-06-19, 06:00 PM   #2
Scittyf
Default Re: Fuel Tank Range
I guess looking at fuelly most people get 50mpg+ and the tank is 17-18 litres. So probably a good 180 miles.
Scittyf is offline   Reply With Quote
Old 03-06-19, 07:13 PM   #3
R1ffR4ff
R1ffR4ff's Avatar
On my 1999 Curvy and depending on how spirited my riding is and my body weight I think the lowest my reserve light started to flash was around 140 miles and if taking easy one time it hadn't come on when I put the bike away after 162 miles.
I don't bother with MPG tests any more and most of my riding is not in traffic.I'm am vigilant on keeping my Tyre pressures correct which is often overlooked for good MPG/Handling and Safety especially on two wheels.
I already had a brass angled Tyre Valve extender but have bought these instead as my old Brass one is still a little difficult to use on the SV,
https://www.ebay.co.uk/itm/143274083714
HTH
Old 03-06-19, 07:45 PM   #4
Flybuster
Flybuster's Avatar
As R1ffR4ff states. My 99 curvy will usually get about 150 miles before the light starts to flash.
Flybuster is offline   Reply With Quote
Old 03-06-19, 08:36 PM   #5
dirtydog
Knob faced knobster
dirtydog's Avatar
I only get about 130 before my fuel light would come on
2001 SV650 in shimmerin green, Not broken anymore
Old 03-06-19, 10:25 PM   #6
garynortheast
garynortheast's Avatar
You'll get as many different answers as there are curvy owners probably.
The light on mine doesn't start to flash until at least 185 miles usually, and I've seen just over 200 miles before refilling on several occasions. I brim the tank on mine when I fill up, by rocking the bike gently and dribbling the last couple of litres in. Even so, I've never managed to get any more than 15.5 litres into the tank when refilling.
Old 04-06-19, 06:57 AM   #7
Biker Biggles
Biker Biggles's Avatar
Get a spare fuel can and strap it to the pillion, then ride until the light comes on and/ or it runs out of fuel.Put spare fuel in tank and ride to garage. This will tell you if the light works and how far you can get after it comes on. All useful to know.
Old 04-06-19, 08:45 AM   #8
johnnyrod
johnnyrod's Avatar
I get about 180 miles, and when the light comes on, it needs 3 gallons/13.5 litres to fill up. Best bet is fill it up, ride for say 100 miles, fil it again and work out your mpg. 60mpg gives 180 miles, and unless I'm caning it, it's pretty consistent to be honest.
Old 04-06-19, 08:55 AM   #9
Scittyf
Which is why I was so surprised when I filled up the SV400 and got 190 miles to 11.12 litres of petrol. Or 77.7 mpg.
Now I know the SV400 has clearly a smaller engine. But if I travel similar speeds to an SV650 it should eat up the same petrol. As weight and aerodynamics won't really change all that much between the two models. So I was pleasantly surprised. Maybe I need to cane it a bit more.
Or probably more likely the speedo is probably wildly optimistic.
Not sure if this is the same as your curvey's but I noticed below 30mph the speedo heavily under reads. Then anything above 60mph looks to over ready by some way. Which is why I think I've got such good mpg.
I think I'd be better off fitting a Bicycle speedometer as I feel that would be far more accurate.
Old 04-06-19, 09:19 AM   #10
punyXpress
punyXpress's Avatar
Are you sure it isn't a kph speedo ?
Also, riffraff's tyre valve extenders:
There's a helluva strain on valves if you consider weight & leverage &
centrifungal force.
Not nice having it leaving the wheel rim at speed !
Now: Street Triple R
Fuel Range on a Pointy? aesmith SV Talk, Tuning & Tweaking 190 01-08-13 11:51 AM
Fuel range on a Curvy? Knobby SV Talk, Tuning & Tweaking 57 26-05-13 10:06 PM
Range from fuel light? K3 granty92 Bikes - Talk & Issues 9 12-02-13 12:47 AM
Fuel range to empty orose 2011 Annual Rideout 50 04-08-11 12:16 PM
Range with fuel light on? speedplay SV Talk, Tuning & Tweaking 11 24-02-09 12:03 PM
