Old 10-04-21, 02:34 PM   #1
rob8781
Junior Member
rob8781's Avatar
Default Coolant level.
When changing the coolant, do I check the level when the bike is on the side stand or when upright?
Thanks.
rob8781 is offline   Reply With Quote
Old 10-04-21, 03:12 PM   #2
SV650rules
Default Re: Coolant level.
Check the coolant reservoir with the bike upright and level ( just like checking oil level ). With the bike on sidestand the level will be about 10mm higher, as long as it is between H and L marks it is OK.
See this recent thread http://forums.sv650.org/showthread.php?t=238724
2016 SV650 AL7
Old 11-04-21, 09:26 AM   #3
R1ffR4ff
R1ffR4ff's Avatar
Thanks.
The bike needs to be level and the engine run until the thermostat opens. I fill the rad just below the Bottom of the neck. You need to sit on the bike and move it left and right carefully and watch for the bubbles to stop once the coolant had flowed around the engine enough with the engine running and the Rad cap off.
You have to be careful not to let the engine get too hot as the coolant will expand and overflow. Once satisfied the cooling system has been, "Burped" you can put the Rad cap on but after a while you should check and top up the level.
The instructions are in the WSM.
The level in the, "Catchment" bottle is not a measure of the level in the radiator. Motorcycles like these use an open-atmospheric emergency overflow system not a sealed pressurized expansion system.
This is a good read,
https://itstillruns.com/coolant-over...-12218289.html
There's several videos on YT to help and this is a decent one,
https://www.youtube.com/watch?v=Bt2eYZMlTFI
Old 12-04-21, 07:04 AM   #4
glang
Any air in the system should rise to the radiator cap which then opens as the coolant expands on heating so expelling the air to the reservoir. Later as the engine cools coolant is drawn back from the reservoir to ensure the system is maintained completely full...
Coolant level scampydog Bikes - Talk & Issues 8 30-08-08 05:43 PM
Coolant Level gavinsky23 SV Talk, Tuning & Tweaking 4 21-05-08 01:28 PM
Coolant level difficulties Nekkid SV Talk, Tuning & Tweaking 1 15-08-06 11:20 AM
Coolant level andyb SV Talk, Tuning & Tweaking 7 01-08-06 08:12 AM
Coolant Level TSM SV Talk, Tuning & Tweaking 3 09-03-05 10:30 AM
