Old 20-06-20, 11:07 PM   #1771
dirtydog
Knob faced knobster
dirtydog's Avatar
Default Re: What have you tinkered with today?
Have been sorting out all the bits for doing my bar conversion so figured if I’m swapping the brake hoses I might as well swap the callipers as well. One of the current calipers has a snapped bleed nipple so needs to be sorted really.
Time to rebuild my spare calipers...
https://www.flickr.com/gp/188588037@N03/3MAz69
2001 SV650 in shimmerin green, Not broken anymore
Old 21-06-20, 09:43 AM   #1772
Sean_Morgan
Finally got round to replacing the bodged/buggered speed sensor
Sent from my SM-G960F using Tapatalk
Sean_Morgan is offline   Reply With Quote
Old 21-06-20, 01:52 PM   #1773
proze
I got the SV all together and went for a spin. It's the first ride since redoing the suspension: New linkage bearings. New-to-me, freshly serviced ZX10 shock. And new oil and springs in the front. It's like someone ironed the road. It's wonderful!
proze is offline   Reply With Quote
Old 21-06-20, 04:37 PM   #1774
dirtydog
Knob faced knobster
dirtydog's Avatar
Calipers painted today, new pistons, seals, pads, pins and bolts ready to go in once the paint has dried
Old 22-06-20, 07:51 PM   #1775
Made this janky OBD2 connector for the Dorsoduro thanks to some smart people on the aprilia forum, in order to find out what is causing the intermittent service lights. It gave some codes relating to the throttle sensors. I'm thinking it might have been caused by me adjusting the amount of free play on it. So I reset the codes and forced it to self learn.
Took it for a short run and no lights so far. I won't be 100% sure it is fixed until I've been out a few more times, but fingers crossed. Plus it's very useful to be able to instantly see any faults without having to go to the dealer. And it cost just £27
Old 22-06-20, 09:36 PM   #1776
Dave20046
Dave20046's Avatar
Nice work Dazzla.
I fitted some Yorkshire O2 sensor correctors the other day and felt pretty proud.
Old 27-06-20, 09:33 PM   #1777
Craig380
Checked the clearances on my Gen 3, which has just turned 15K miles. All in spec, thankfully, so good for another 15K+. Getting the rear valve cover off and replacing it was a bit of a knuckle scraper because I didn't remove the tank, but got there in the end.
Old 27-06-20, 10:16 PM   #1778
Originally Posted by Adam Ef View Post
Oil etc arrived for CRF fork investigations today. Also got an email through from JHS saying they will only check the forks as part of a full service on them at £150+vat. They won't look at them taken apart as i intended to take them along to them.
you need special tools to work with cartridge forks. the cost is about £100 for the tools. if you have an impact gun.
biggest mistake people make is not 'degassing/bleeding' the cartridges when they add oil. you also get the same problem with people doing the same with damper rod forks.
as long as your not stripping the cartridges down to change the valve shims then this are easier.
Old 28-06-20, 11:28 AM   #1779
Adam Ef
Adam Ef's Avatar
I won't be doing anything with cartridges.
Looks like I won't have to go anywhere near that far. Opened up the RH fork and got 200ml of oil out of it instead of the recommended 650ml+. Suspect the LH fork will be the same.
I've got the seals, bushes and a new spring so I'll be fitting that anyway and getting it back together with the correct oil level. The slide smoothly when empty and off the bike so hoping nothing is bent.
Past:
Old 28-06-20, 01:58 PM   #1780
I won't be doing anything with the cartridges.
I've got the seals, bushes and a new springs so I'll be fitting that anyway and getting it back together with the correct oil level. The slide smoothly when empty and off the bike so hoping nothing is bent.
unless you have a good spring compressor its a nigilymare of a job.
https://www.ebay.co.uk/itm/NEW-Seale...4383.l4275.c10
Been got already today.. 454697819 Idle Banter 16 01-04-10 02:08 PM
Today DaveP The Border Patrol 4 02-03-10 10:52 AM
Going out today? tj2 The Border Patrol 1 01-06-09 09:22 PM
Today Tara Guildford Massive 14 02-06-08 11:56 AM
Today...... Caddy2000 Idle Banter 15 19-04-06 05:39 PM
