Old 27-08-07, 03:28 PM   #1
stevenford_uk
Default sv 650 gearbox prob
hey everyone, i have just bought a light crash damaged 2002 plate sv 650.
it had minor bodywork scrapes and the footpeg and gearlever had broken off.
the work on the bike has now been done, came to ride it and it is very very difficult to select neutral, the neutral light never comes on, when the engine is off in neutral and the starter is pressed it jumps into gear! also when riding the change from 3rd to 4th is very difficult and not always possible.
it is deffo not clutch drag, does anyone have any experience of this or know what the problem could be?
thanks
steve
Old 27-08-07, 07:52 PM   #2
fizzwheel
fizzwheel's Avatar
Default Re: sv 650 gearbox prob
Some things to check
Oil Level
Chain Tension
I found before to much oil and it effects the gear change, as does slack chain.
After that if you're confident your clutch is adjusted properly the other thing to do is take the gear lever off its pivot and give it and the pivot a good clean, theres also a fibre push in the lever that you can gently lift out and and again clean, and then put it all back together with a liberal helping of grease and it should make a a big difference.
I'm not 100% sure of the process of removing the fibre washer, I know you have to be really careful with it and I wasnt brave enough to take mine out, however theres a very good post by Sid Squid on the subject that if you search for you should find and it'll explain the process.
Old 28-08-07, 06:56 AM   #3
Adjust the clutch as if it were your life's very purpose.
If there's any question of a sticky lever check for my posts on ensuring that the lever pivot is right.
Even if you think the clutch isn't dragging it may be worth checking for damage on the clutch basket, (plates hanging), this will make gear selection awkward.
Failing that, as it's had a whack on the gear lever, you'll need to see if there's selection problems, you'll already have the clutch cover off so the external parts will be accessible, (if you remove the clutch basket), - lets hope the problem isn't any deeper, selector forks and drum require the motor to be split.
Old 28-08-07, 03:49 PM   #4
stevenford_uk
its deffo not the lever or clutch basket, both have been checked.
looks like i might have to split the lump.
thanks
Old 31-08-07, 05:33 PM   #5
stevenford_uk
i have been playing around with the lump and have discovered the source of the prob, the selector drum has small dowels coming out of it and one of these has broken off, can the selector drum be removed or does the lump have to be split?
Old 01-09-07, 06:51 AM   #6
Spanner Man
Good morning.
The motor will have to be split to remove the selector drum itself, however it looks as though you can remove the selector drum plate with the engine in situ, which is the bit I assume you mean, by removing the bolt in the centre of the selector drum.
Also check the selector claws on the gearchange shaft for any damage, for it would have been one of those that snapped the dowel off in the first instance.
Cheers.
Spanner Man
Old 01-09-07, 08:42 AM   #7
Richie
fantabulas
Richie's Avatar
You'll have to split the lump... as spanner man say, sounds as if the bike was dropped on the gearchange side and that has caused all the internal damage.
Whilst it's apart it a good time to check all the other things you need to check for a full engine service.
My Flickr photos
Old 01-09-07, 10:58 AM   #8
Richie
fantabulas
Richie's Avatar
Give Northwind a PM as I got his gearbox but he still got the selector drum for the Curvy engine...
hope you get your problem sorted out.
My Flickr photos
Old 01-09-07, 12:02 PM   #9
Yeah, I should have a spare somewhere, but I'm none too sure what I did with it... I'll have a look, if you want it.
Old 02-09-07, 02:36 PM   #10
stevenford_uk
so if its just the drum on the end it can be replaced with the engine in situ?
is the bolt recessed in the center if the drum??
CBR 125 prob suzsv650 Bikes - Talk & Issues 4 23-04-09 12:07 PM
Was doing some mods then had a prob! Jamesie SV Talk, Tuning & Tweaking 5 07-03-09 07:53 PM
SpeedO prob jonhunt Bikes - Talk & Issues 5 02-02-07 05:17 PM
vibe prob? goldengraemes SV Talk, Tuning & Tweaking 2 30-03-05 08:15 PM
