06-02-22, 06:28 PM | #1 |
Chain
What sort of quality is the original Suzuki chain fitted to the SV650A? I can't seem to stop the chain on my 2020 SV650 from rusting even though I have a Scottoiler fitted and clean the chain periodically with paraffin and rub oil on it with a sponge or soft brush .
06-02-22, 06:53 PM | #2 |
Re: Chain
I had the chain replaced on mine at 30k miles but only because I wasn't sure how long they're supposed to last. It didn't appear worn by the pull-it-off-the-rear-sprocket test. I only adjusted it 5 times in 5 years so I'd say it was a pretty good chain.
I've noticed that modern chains seems susceptible to surface rust on the side plates so I wipe mine down with an oily rag soaked in 30W gear oil over the winter. Not had any problems since.
2016 SV650AL7 2023 GSX-8S |
06-02-22, 07:26 PM | #3 |
Re: Chain
I'd not worry about the rust, per se as it's probably just a surface rust rather than a structural kind.
08-02-22, 10:05 PM | #4 |
Re: Chain
Think I will brush the side plates with a brass wire brush and then coat with gear oil as suggested above.
I had a couple of bikes in the past with gold chains and they seemed better to keep clean. |
09-02-22, 12:29 PM | #5 |
Re: Chain
if the chain has started rusting on the plates then nothing will stop it as the "skin" has been broken. you could try applying a rust cure like rust eater to each individual plate. or an even better idea and its what i do cover the plates in a good quality grease based no fling chain spray and dont clean it.
if you have ocd then get a gold chain. |
09-02-22, 08:29 PM | #6 | |
Re: Chain
10-02-22, 09:54 PM | #7 |
Re: Chain
Still on the original chain on my Gen 3 at 33,000 miles - it's still within the wear limit. Mine also shows rust on the side plates if left unattended during winter. I brush a little ACF-50 on every month which really helps keep it at bay.
11-02-22, 11:00 PM | #8 |
Re: Chain
I cheat and use a Chain Oiler. No rust, occasional maintenance and the chain is always good to go. I use Tutoro, but other brands are available.
12-02-22, 06:55 PM | #9 |
Re: Chain
13-02-22, 11:25 AM | #10 |
Re: Chain
Same here and I use GT85 PTFE chain lube ( Usually cheap at Wilko supermarkets or ASDA) to keep the chain lubed and all my lever/brake joints etc.
Chain reaction (not a bike chain) | Seeker | Idle Banter | 0 | 17-12-19 09:22 AM |
Naked curvy chain guard and chain | Squatepantz | Stuff Wanted | 0 | 10-05-11 07:41 PM |
Which chain adjustment marker (new chain) | rockster | SV Talk, Tuning & Tweaking | 14 | 22-11-09 02:12 PM |
Morax Gold Chain Wax / Wurth Chain Wax | glade | Ancillaries | 3 | 14-02-08 06:41 PM |
Will stiff chain link cause chain noise | dclifford | SV Talk, Tuning & Tweaking | 8 | 16-08-05 11:56 AM |
