16-09-09, 07:55 PM | #1 |
No Spark
650s(y)curvy no spark... had a look in the workshop manual... plugs ok, ignition coils passes test, pulse coil generator passes test.throttle position sensor passes test. anybody got any ideas or will i have to track down a CDI unit.
Dreams & Screams go hand in hand |
16-09-09, 08:59 PM | #2 |
Re: No Spark
i had a similar problem with the last bike i owned a gilera nexus 500, it turned out it was something to do with the immobiliser that was fitted, so if your bike is fitted with an immobiliser it might be worth getting it checked out!
16-09-09, 09:07 PM | #3 |
Re: No Spark
Earth to the ignition switch needs to see a resistance of 100ohm, manual doesn't say owt about this.
16-09-09, 10:56 PM | #4 |
Re: No Spark
1st there is no immobiliser fitted so it can't be that. Thanks
2nd just raised the tank disconnected the connector took a Reading of 105. I'm thinking CDI or a break. . . . Thanks boys
17-09-09, 01:40 AM | #5 |
Re: No Spark
tried the safey (read annoyance) features eg cluch switch and side stand switch
17-09-09, 09:22 AM | #6 |
Re: No Spark
There's me spotting zebras.
Aye, check for +12v at coil lives and ICU box connector with ignition on. If you have +12 there then the sidestand cutouts etc. are OK.
17-09-09, 09:45 AM | #7 |
Re: No Spark
engine turns so cutouts cant be the prob......
17-09-09, 10:27 AM | #8 |
Re: No Spark
Could be a break in the wire supplying power to the coils and ICU box though.
17-09-09, 04:23 PM | #9 |
Re: No Spark
If it's not the cdi then I'm either going to check every wire one at a time. Or torch the ******* ( in a Viking style type cremation)
17-09-09, 07:17 PM | #10 |
Re: No Spark
Have you actually tried a new spark plug...
RIP Reeder 20/07/1988 - 21/03/2012 |
No Spark | yorkie_chris | SV Talk, Tuning & Tweaking | 27 | 15-09-07 05:29 PM |
no spark | hovis | SV Talk, Tuning & Tweaking | 10 | 27-06-07 03:19 PM |
spark plugs | daddy_sperm | SV Talk, Tuning & Tweaking | 12 | 01-03-06 06:12 AM |
No spark...please help. | leegriffiths128 | SV Talk, Tuning & Tweaking | 0 | 11-11-05 05:17 PM |
spark plugs | weegaz22 | SV Talk, Tuning & Tweaking | 4 | 04-08-03 05:04 PM |
