Old 09-06-08, 02:37 PM   #1
Blue_SV650S
Default Extending the stock shock
Ok, ground clearance on a stock SV is poor. There is the shorter dogbone trick, but this is limited.
My track SV has an ohlins rear shock, I can tell you for nothing the biggest difference it makes is in where you can adjust the ride-height!! You really can wind the shock up!! But race shocks are stupidly expensive ... and I am not sure the largest gain is actually in the more controlled damping, just in the ride height ...
So this leads me on ... has anyone actually tried extending a stock SV shock? To my mind making longer fork bottoms seem to be the simplest way?
Old 09-06-08, 02:52 PM   #2
Dangerous Dave
Default Re: Extending the stock shock
Not tried it but I have looked at it and I agree with you Blue that the longer fork bottoms (lower mounting bracket) is the safest and easiest option to take.
Extending the stock shock Blue_SV650S SV Talk, Tuning & Tweaking 28 03-11-08 01:50 PM
Thinking of reverting back to stock shock ... Blue_SV650S SV Talk, Tuning & Tweaking 31 19-09-08 12:33 PM
Extending the fuse box. Grinch SV Talk, Tuning & Tweaking 5 26-06-07 09:47 PM
GSXR rear shock stock spring rates lukemillar Bikes - Talk & Issues 3 07-05-06 01:38 PM
stock sv1000 shock settings mac650s SV Talk, Tuning & Tweaking 1 26-11-05 09:12 PM
