Old 16-01-26, 08:59 PM   #1
How2
Junior Member
Default 2014 Gladius //F1code
Hello
I picked up this fairly clean dead battery non runner bike with 8k miles in the US.
After putting in a new battery, bike powers up, but no start.
An article found indicates a "dealer mode" can target the problem. Its engaged by finding a white terminal with a black cap . I don't see it
Can someone send a photo of this and its location?
This project could be simple or slime.
thanks
H2
How2 is offline   Reply With Quote
Old 17-01-26, 10:38 AM   #2
admin
John T
admin's Avatar
Default Re: 2014 Gladius //F1code
https://forums.sv650.org/showthread.php?t=223121
Old 17-01-26, 03:04 PM   #3
glang
Originally Posted by How2 View Post
Hello
Youre on a UK site here but no problem. With your query if you dont have the FI light showing there wont be any code to see. If so its much more likely to be the clutch lever or side stand switch etc as these interlocks have to be made to get a start...
Old 18-01-26, 02:35 AM   #4
How2
Junior Member
hello
Thanks for the link to the photos. While waiting for a reply , connecting sockets were checked for corrosion / breakage.
I pulled the relay located just next to the fuse box and starter relay, for a look/ see. Nothing noticeable but the bike started right up and the F1 code disappeared right after re install.
Herez a pic.
thanks
H2
[IMG]file:///C:/Users/twofo/OneDrive/Pictures/2--%20BIKES/GLADIUS/20260117_180800.jpg[/IMG]
Old 18-01-26, 08:34 AM   #5
glang
Good and yes they can suffer with electrical system corrosion. Here in uk many owners spray all connections with protection for our wet winter weather and salted roads☹️
Old 18-01-26, 11:04 AM   #6
admin
John T
admin's Avatar
Glad you got it sorted.
Old 19-01-26, 09:02 AM   #7
garynortheast
garynortheast's Avatar
As has been said, it's worth using something to keep the crap out of the connector blocks. give them a good clean and then a small amount of ACF50 will keep any corrosion at bay.
Blue Curvy S with over 112,000 miles and still going strong.
Old 19-01-26, 02:37 PM   #8
R1ffR4ff
R1ffR4ff's Avatar
I use ACF50 On all my electrics and also on top of the relay/large Block connector under the tank and my Spark plug caps a smear a thin amount of some Dielectric grease as extra protection
Dielectric Grease eBay
SV v Gladius? pie eater Bikes - Talk & Issues 15 20-03-13 10:01 AM
Gladius 650 Stephen McG SV Ecosse 14 31-05-10 11:05 PM
Who else has a Gladius? madjohn SV Talk, Tuning & Tweaking 28 15-06-09 04:16 PM
gladius kwak zzr Photos 68 15-05-09 11:55 AM
Gladius What do you think Smudge Idle Banter 4 19-11-08 06:17 PM
Powered by vBulletin® - Copyright ©2000 - 2026, Jelsoft Enterprises Ltd.
