Old 25-10-18, 01:14 PM   #1
Seeker
Seeker's Avatar
Default PSA number and bicycle riding
My urologist asked me if I was a cyclist when we talking about my (high) PSA number. The question whooshed over my head because he'd just told me my MRI was free of abnormalities.
Later, I thought: "what?" and googled it.
Indeed cycling can cause your PSA number to be higher than normal.
https://www.telegraph.co.uk/news/hea...te-cancer.html
I don't ride a bicycle but I ride a lot of bumpy country lanes and I learned that if the prostate gets irritated your PSA will rise. At least we now have a medical reason for justifying expensive suspension upgrades.
Old 25-10-18, 08:27 PM   #2
Default Re: PSA number and bicycle riding
Suspensions for whimps
I just use a good quality pair of cycling shorts, and a saddle with a pressure relief channel.
The only time I've had problems is when I've taken the saddle off, and not put it back at the wrong angle, ie nose up.
I have more problems with aching back during a ride, than painful undercarriage
Old 25-10-18, 10:46 PM   #3
chris8886
chris8886's Avatar
are you suggesting that your not as well endowed as some then?!
AR08 to AR13-QUALITY!
Old 26-10-18, 07:06 AM   #4
Never had any complaints
Old 26-10-18, 07:38 AM   #5
Talking Heads
What's a PSA?
Not a Citroen I presume.
Talking Heads is offline   Reply With Quote
Old 26-10-18, 07:51 AM   #6
Seeker
Seeker's Avatar
Originally Posted by Talking Heads View Post
What's a PSA?
you must be young. PSA is prostate specific antigen, it's a very inaccurate measure of what your prostate is doing. It should yield a number less than 3 if you're ok. I don't know if there's an upper limit, 3-11 means: uh oh, and above 11 klaxons go off. A high number means: 1) you're older and have an enlarged prostate or 2) may have prostate cancer. Some infections can cause a higher number as can having sex (before the test) or vigorous exercise...it's linked to testosterone.
Unfortunately it can give false positives and false negatives. The medical profession recommend men (of course) having regular PSA tests from the age of 50.
And as a PSA (Public Service Announcement) about your PSA and prostate: The prostate is a small, walnut sized gland that is wrapped around your urethra, as it grows (as you age) it can affect your urine flow and often manifests itself as frequent night time urination or the feeling that you need to pee immediately after you just pee'd or general low flow. Only men have a prostate.
Old 26-10-18, 09:02 AM   #7
keith_d
keith_d's Avatar
I read a statistical critique of the PSA test some years back. The number of false positives and false negatives make it almost worthless. Basically if you have a high level of PSA they'll do some more investigation. But there's a fair chance it's nothing to worry about.
Old 27-10-18, 10:35 PM   #8
Heorot
In my case, I was told that up to 5 was normal and as soon as it rises above that it needs monitoring more frequently. After extra monitoring, I was sent for tests because my PSA was 7.5. It turned out that a quarter of my prostate was cancerous. However, I have a friend whose PSA is in excess of 20 and has regular tests but, so far, it's not cancerous.
Some say the cup is half empty, while others say it is half full. However, both are wrong; the real problem is the cup is too big.
Honda 125 CG blown engine Gone to the great mechanic in the sky
Naked SV650 K3 in Silver
Heorot is offline   Reply With Quote
Old 28-10-18, 02:29 PM   #9
Talking Heads
Seeker, you're spot on, I am young, just a lad of 57 years young.
Old 28-10-18, 04:26 PM   #10
Seeker
Seeker's Avatar
then if you haven't had a PSA test, I recommend you get one.
Which is the best bicycle I can buy... thulfi Idle Banter 1 24-10-11 07:03 PM
D lock for a Bicycle sauluk Bikes - Talk & Issues 15 04-03-10 10:50 AM
A dumb attempt at trolling number 3. (Err... That'll be number 4, but Bondy-Boy got a bit confused) bondwest SV Talk, Tuning & Tweaking 55 14-11-09 09:20 PM
bicycle burnout Shinsei Jutsu Idle Banter 11 21-06-06 07:21 AM
