06-03-07, 09:10 AM | #1 |
Cut out when clutch pulled in
Going along quite happily when a car stopped infront of me, so I pulled the clutch in to change down and tried to blip the throttle, but nothing. Had the oil warning light on and no engine. I restarted and carried on for the rest of the 25 mile trip it was fine. What could this be? It happened after about 10 miles so the bike was upto temp etc.
Any help/ideas appreciated. Its just knocking my confidence a bit as it I'd have not realised and just let the clutch out again I'd have prob had a brown trouser moment |
06-03-07, 09:18 AM | #2 |
Re: Cut out when clutch pulled in
my pointy has just started doing that to me, i pull the clutch in and start to change down and it stalls, but mine is aalways within the first few mins of getting on, its probably because i rev the bolox of it
06-03-07, 09:37 AM | #3 |
I had this with my SV when first got it, it would cut out like that for no reason. I turned up my idle speed to around the 1500rpm mark and its been fine ever since.
06-03-07, 09:58 AM | #4 |
Thanks for advice, I'll check out the idle speed although think it may be OK as it didnt stall when it was cold with the clutch pulled in.
06-03-07, 10:10 AM | #5 |
My curvy will cut out if it isnt idling above 1500rpm; this is only when its cold though.
Matt |
06-03-07, 10:12 AM | #6 |
The Sick Man
Yep happened many a time, but also sometimes when hot.
OTR: KTM 690 Duke R 2015 Full Akro SIDELINE: Kwak ZX636 A1P 2002, Red, R&G's, Yoshi, Double Bubble Screen GONE: Kwak ZX-7R P1, Full Akro, Undertray, Screen GONE: SV650S K2 Very Bruised & Without Fairing, Motovation Frame Sliders, R&G Ally Sprocket Toe Protector, HEL 2 Line Setup, GSXR K1 600 RWU Forks, Barnett Clutch & Springs, Penske 8981 Shock, Gilles Ti Rearsets, Steel Barends, Scottoiler, AFAM Chain & Sprockets, Twin FIAMM Horns, Skidmarx Bellypan, Full Micron Zeta Steel System, Cut down undertay. Forum Problems & Information / Site Suggestions |
06-03-07, 10:13 AM | #7 |
Did you sort it TSM or just learn to live with it?
06-03-07, 10:21 AM | #8 |
Of possible benefit, if you bridge the clutch switch it takes it out of the equation (for testing of course).
Cheers Mark.
06-03-07, 10:30 AM | #9 |
The Sick Man
Does not happen that much, there are several things that have to concure at the same time usaly for it to happen, either a slow gear change (e.g. not a positive direct shift), after a long stint at high load then right down to pottling speed and change gear slowly. So not a big issue and not often, but i live with thoes problems as they are minor in the bigger picture of my bike.
06-03-07, 10:35 AM | #10 | |
pulled up | Frank | Bikes - Talk & Issues | 34 | 04-10-07 02:37 AM |
Cutting out when clutch pulled in | John 675 | SV Talk, Tuning & Tweaking | 20 | 19-05-07 06:28 PM |
Engine tone changes when clutch is pulled/released | rich_r | Bikes - Talk & Issues | 12 | 14-11-06 08:58 PM |
Pulled Over, WHY ? | Viper | Bikes - Talk & Issues | 49 | 26-10-06 12:44 PM |
Pulled Over, WHY ? | bbanna | South & West Surfers | 1 | 08-01-70 06:58 PM |
