16-10-18, 07:46 AM | #31 |
Re: Rear brake still sticking after servicing.
Wow, crazy. TBH I haven't read the whole thread. When the caliper is off the bike, can you pump the lever and see the piston retract even a slight bit? And does the piston move back with assistance easily? Wondering if a seal might be on the wrong side out or something? Long shot, but might be the case.
93 VFR750 - WAY too many mods to list. Crashed 04 SV1000 - Bar end mirrors. Belly pan. Seat cowl. K4 GSXR600 K6 front end and custom top yoke. R6 Brembo MC |
16-10-18, 09:26 AM | #32 |
As far as I know the seals fitted were square. Should they be tapered, and if so which way out?
16-10-18, 10:58 AM | #33 |
Lumpy ridge facing outwards, flat surface sits in the groove
16-10-18, 11:00 AM | #34 |
I will check the caliper I removed...
16-10-18, 11:01 AM | #35 |
Cool, fingers crossed!
16-10-18, 04:17 PM | #36 |
Seals on the problematic caliper that I removed look square. When fitted they do have a ridge which sits slightly proud on the inside. This made me think it was the wrong way around, so I flipped it and the ridge is still on the inside. Something to do with the seal recess? The seal definitely looks square when removed. I've cleaned the inside of the caliper and seal recesses when I fitted the new seals and piston a few months ago.
16-10-18, 04:44 PM | #37 | |
I'd it a sliding caliper like the fronts, or a solid unit? Maybe the sliding pin is fudged. All seems really odd this!
16-10-18, 06:58 PM | #38 |
It's working fine now with the original fixed caliper back on there, and that's using the pins from the one that wasn't. Process of elimination suggests there must be a problem with the caliper. Be good to say what though in case it can help problem solve for others in the future. For now my only fix has been to put my old caliper back on with the mounting thread recut straight (the reason it was removed and replaced originally).
17-10-18, 10:52 AM | #39 |
i'll put it down to the new SS piston, it might be slightly bigger than the OEM one.
17-10-18, 12:35 PM | #40 | |
This had crossed my mind too. I've kept the original piston in the caliper that's fitted and working. The way to find out would to be put the SS piston into the caliper that's currently working and see if it stops working. Not something I'm going to do right now having swapped it all about several times the last few days. Maybe next time I change the seals. The SS piston was easy enough to push back in by hand though. Similar in feel to the original. Tolerances must be fairly fine on them though. |
Thread Tools | |
Rear brake caliper sticking? | Rogue_Shadow | SV Talk, Tuning & Tweaking | 11 | 10-03-14 04:53 PM |
Rear Brake pedal sticking | Woogie | Bikes - Talk & Issues | 3 | 05-03-13 08:06 AM |
Brake sticking. | Elltg | Bikes - Talk & Issues | 13 | 08-04-10 11:08 AM |
Brake light switch sticking on with front brake | rick0361 | SV Talk, Tuning & Tweaking | 6 | 11-06-09 06:20 PM |
Sticking rear brake lever | Haxsaw | SV Talk, Tuning & Tweaking | 11 | 18-04-05 02:35 PM |
