Old 04-11-18, 02:32 PM   #1
aesmith
Default Pointy 650 - real world fuel capacity?
According to the user manual the fuel tank is 17.0L. What I was wondering is what is the most that anyone has ever managed to fit in, or get out of the tank. For example last time I filled it took 16.8L, so I know it takes at least that much. But I don't know if it was right on the point of running dry, whether there really was 200ml that could still have been used, or indeed whether I am over filling the tank compared to the manufacturer's expectation.
Cheers, Tony S
Old 04-11-18, 04:11 PM   #2
Craig380
Default Re: Pointy 650 - real world fuel capacity?
I usually fill up within 10 miles or so of the fuel light starting to flash, and if I absolutely brim the tank right to the filler neck I can get maybe 12.5 litres in (K6 S).
Did you have a solid fuel light when you squeezed 16.8 litres in?
Old 04-11-18, 04:39 PM   #3
shiftin_gear98
shiftin_gear98's Avatar
I once got in just over 17 litres. I think I was moments from pushing though.
Old 05-11-18, 02:02 PM   #4
aesmith
Light had been solid for around 17 miles before I filled up that time, maybe a little more. To be honest I left it a bit later than usual that time. I normally get four days between fills and only take just over or under 16L. This time I had a bit of extra mileage from test runs after doing the brakes, plus some more starts and stops so a bit more miles ridden and a bit of extra fuel used.
I guess the only way to be sure would be to run out, then push the bike to a petrol station and see how much it takes. I'm not that dedicated.
Old 05-11-18, 03:58 PM   #5
shiftin_gear98
Having pushed to a petrol station twice. It's not much fun.
Unfortunately I didn't notice how much juice it took.
Old 05-11-18, 05:03 PM   #6
Craig380
Amen to that. I've only had to do it with my old Suzi GT380, but it was a mile and mostly uphill. No fun at all with all the gear on
Old 05-11-18, 06:57 PM   #7
shiftin_gear98
Last time was in the middle of the heat wave we had this year. I too had to push for about a mile to the station, uphill in the blazing sun. I think I sweated more than 17 litres due to all my gear. What really ****ed me off was that once full it just refused to start. So a lot of swearing and another mile or so till I found a hill big enough to try bump starting it, something I'd never tried before. Thankfully it worked, as I was 8 miles from home and really not happy about the thought of pushing it that far.
I tend to wuss out now and fill up shortly after the light comes on.
Old 05-11-18, 09:58 PM   #8
Ruffy
Ruffy's Avatar
I think I must be old. I still use the old school technique of zero-ing the trip when I fill up and go looking for fuel around the 130-140 mile marker. Learnt back in the day, before many bikes had a fuel gauge/light.
(I have been saved by a reserve tap on a number of occasions, though, so not a perfect technique.)
Spannering the wife's SV650S K5 pointy in Black, and son's SV650 X curvy in Blue.
RIP SV650 X curvy, crashed and written off December 2019.
I'm (procrastinating about) fixing up an old Yamaha FZ600 to get myself fully back on the road.
Ruffy is offline   Reply With Quote
Old 05-11-18, 10:47 PM   #9
Adam Ef
Adam Ef's Avatar
Originally Posted by Ruffy View Post
...zero-ing the trip when I fill up and go looking for fuel around the 130-140 mile marker.
I do that but have recently still had the light flashing at 160 miles. Usually starts flashing around 135 and I normally fill up well before 150 just to be safe.
Old 06-11-18, 06:36 AM   #10
shiftin_gear98
I'm pushing mine at 140. Anything past 135 and I'm risking it. But yes I too reset the clock every time I fill up.
Real world mpg BigFootIsBlurry SV Talk, Tuning & Tweaking 18 11-03-15 10:53 AM
Fuel Tank Capacity & Reserve? slloyd SV Talk, Tuning & Tweaking 55 21-07-11 02:46 PM
Overrun issues and decreased fuel capacity Al_Sweetman SV Talk, Tuning & Tweaking 9 27-09-07 09:09 AM
REAL-WORLD Tool Definitions Supervox Idle Banter 2 19-05-06 01:33 PM
fuel light - capacity ? Tommy_Tank SV Talk, Tuning & Tweaking 13 20-01-06 04:50 PM
