Old 07-06-08, 05:24 PM   #1
ctink78
Default Sat over the winter
I currently own an 04 sv650, I let it sit over the winter now it won't run. I've replaced the Batt, and the plugs still nothing. Took it to the dealer they said it could possibly be injector related, 50/50 chance and almost $1000. Not good odds! Any advise? Or help? Thanks
Old 07-06-08, 05:32 PM   #2
Default Re: Sat over the winter
1st bit of advice your dealers are f###ing useless.
Has it got a spark and is it fuelling? Are the plugs wet? Does the fuel pump prime?
Old 07-06-08, 05:36 PM   #3
Dangerous Dave
Follow Chris' advice above, he appears to be good at this stuff!
Old 07-06-08, 05:45 PM   #4
ctink78
I'm currently at work but get home a little after two. I'll check those things out when I get home. Have you ever come across this before? If so what was the issue?
Old 07-06-08, 07:38 PM   #5
ctink78
Checked it out, fuel pump primes, and has spark. Now what?! I really dont want to take it to the dealer if I dont have to!
Old 08-06-08, 07:35 AM   #6
xbox650
try and look in the search menu as I'm sure I have seen many post about bringing you bike out of hibernation before .
Old 08-06-08, 11:55 AM   #7
So it's cranking over OK?
Is it firing? popping and banging?
Is the FI light on?
Old 08-06-08, 03:07 PM   #8
ctink78
It does crank over fine. Could the injectors be clogged?
Old 09-06-08, 11:59 AM   #9
Answer the other questions and I'll tell you
Old 09-06-08, 02:00 PM   #10
ctink78
cranks over, has spark, fuel pump does prime, no start. didnt notice if the FI light was on or not. battery is now charging cause i ran it down. sat for 3 months in my garage.
Winter :( Mimu Photos 3 03-11-06 11:29 AM
winter on the way jonhunt Bikes - Talk & Issues 19 02-09-06 05:41 PM
The SV in winter pigletfixer SV Talk, Tuning & Tweaking 15 27-06-06 11:43 PM
After winter... El Saxo SV Talk, Tuning & Tweaking 12 12-03-06 09:47 PM
My SV through the winter falc Photos 18 23-02-06 12:34 PM
