Old 31-03-17, 04:32 PM   #1
daktulos
daktulos's Avatar
Default Turn signal switch
After replacing the front brake lines and rebuilding the front callipers yesterday, I went out for a nice long ride today to check the brakes were working(!) All good, and the engine felt smoother than it has for a long time (not due to the brakes, probably just because I've been out more consistently).
Very happy, until I noticed that I wasn't indicating left.
So, I took the airbox off and unplugged the big connector - no continuity when indicating left, so it's definitely the switch. Switch cleaner (IPA) had limited effect, but after giving the contact a good scratch with a screwdriver, it's working consistently now. Switch mechanism re-greased and put back together and I'm good to go.
But scratching corrosion off a switch contact isn't a long-term solution, so I fully expect it to go again. They're £130 new (and surprisingly in stock) but I was looking at some second-hand on eBay - even though they're used, I could take it fully apart to refurbish if needed.
Before I waste money, does anyone know what the compatibility is like? I have a naked curvy from 2000. The 'S' models and the K1-K2 models have different part numbers, even though they visually look the same. I'm guessing different loom lengths or connectors?
Thanks.
daktulos is offline   Reply With Quote
Old 04-04-17, 08:58 PM   #2
mep
mep's Avatar
Default Re: Turn signal switch
Might be worth checking the earth. I had a similar problem and there are a few threads here about indicator problems. There are a few things to go wrong so check everything before spending anymore than you need to.
mep is offline   Reply With Quote
Old 05-04-17, 10:20 AM   #3
daktulos
daktulos's Avatar
Thanks. I'll invest in some dielectric grease if it happens again.
Crash.NET - Crutchlow 'fell at turn one, nearly landed at turn two' NewsBot News 0 12-11-14 06:20 PM
Turn signal and position light connectors? bellisan SV Talk, Tuning & Tweaking 2 24-02-13 11:11 AM
'02 Blade - Turn Turn Turn... Won't Fire? JamesMio Bikes - Talk & Issues 21 07-10-11 06:27 PM
Front turn signal light (L) problem Slawuch Bikes - Talk & Issues 1 20-08-11 04:52 PM
Curvey SV turn signal/side stand relay diodes Zombie Jesus For Sale - SV's and SV related items 0 03-05-10 07:53 PM
