Old 25-02-07, 05:40 PM   #1
Default Rusty Yoke
Not actually sure if its called the yoke but it's rusty anyway
It seems weird because the rest of the bike is fine, and its only a K3!
Is this just Suzuki using cheap metals or is there something in particular causing it. Sometimes when the radiator is wet and the bikes running a lot of steam comes off it, could this be causing it?
And is there anyway I can remove it, or at least stop it from getting worse
Old 25-02-07, 06:03 PM   #2
DoubleD
Default Re: Rusty Yoke
Got the same on my K4 and as you the rest of the bike is fine.
Not much help to you but your not alone on the rust.... I have a rag in the shed covered in WD40 that I wipe it down with a much as I can on the bits I can get my hands too, seems to help slow it down...
Old 25-02-07, 06:06 PM   #3
autosol gets that off.
Old 25-02-07, 08:00 PM   #4
Rich
Rich's Avatar
Use the autosol and then spray it with Scottoiler FS365 corrosion protector. that should help keep it away
RIP Hovis - Unlucky Boyo
Old 25-02-07, 10:46 PM   #5
Grinch
Mines been like that for years... its just seems to get to a rusty point and then just tail off.
Old 25-02-07, 11:02 PM   #6
Cheers everyone, glad I'm not the only one
I'll give the autosol a try
I Have Rusty Nuts. ooger Idle Banter 6 28-03-09 10:00 PM
Rusty wheels!! djt_spurs SV Talk, Tuning & Tweaking 3 22-01-08 05:54 PM
My Italian is quite rusty... Razor Bikes - Talk & Issues 12 11-02-07 11:03 PM
rusty looking chain.... craigk SV Talk, Tuning & Tweaking 26 03-01-07 12:04 AM
Rusty bit!! pedrosis SV Talk, Tuning & Tweaking 3 28-06-05 12:48 PM
