Old 17-06-07, 05:32 PM   #1
sv650nutter149
Default bang!!!!
hey all got a sv650 k5 and today engine seized.... can i get it fixed under warranty??? one problem i got a aftermarket pipe and kn filter on it will this void the warranty????
cheers
ian
Old 17-06-07, 05:36 PM   #2
Manguish
Default Re: bang!!!!
They'll not do it i guess as the aftermarket parts directly affect the engine.
If it had of been aftermarket wheels or something, the the warranty could not argue the fact the wheels caused engine to sieze. But airfilter/zorst - i suspect they'll not do it.
Good luck.
Old 17-06-07, 05:39 PM   #3
cheers
ian
any reason why it seized? sv engines are usually strong, was it all serviced and up to date?
Old 17-06-07, 05:58 PM   #4
Alpinestarhero
Engine seizures are quite rare in any modern engine - did it have ejnough oil in it?
Matt
Old 17-06-07, 06:00 PM   #5
Well Oiled
Wouldn't have thought the exhaust could be used as an excuse. The air filter maybe. If defective it could affect engine wear. However, you only fittted the K&N the other day , so why not re-fit the OEM filter before claiming?
Old 17-06-07, 06:00 PM   #6
Razor
did ya wheelie it and not check the oil?
Old 17-06-07, 06:18 PM   #7
Alpinestarhero
Matt
Old 17-06-07, 06:20 PM   #8
ivantate
The dealer will need to see a service history and there would be no problems with the mods.
But it will be easy for them to spot damage caused from not having oil in the engine. (every part damaged not just 1 bearing gone kind of thing.)
Old 17-06-07, 07:08 PM   #9
sv650nutter149
servicing all up to date. no wheelies no signs of oil starvation oil loads in engine, will take power commander off tomoz
Old 13-07-07, 08:31 AM   #10
dradonkey
Know the feeling mate.
My SK2 has just done the same for the second time with only 2k miles since new crank fitted.
Found out off web that Suzuki America did a recall in 2000 for problems with oil pump sucking in air on twisty roads.
No warnings, oil light off, oil level ok just locked up solid at 50mph on a left hander. Took a few mins to pull my undies back out after that
chitty chitty fecking bang bang hovis Idle Banter 35 03-01-09 12:33 PM
Big bang R1 Sean_C Bikes - Talk & Issues 78 24-10-08 09:36 PM
Bang! jumjum_0214 Bikes - Talk & Issues 25 23-07-08 08:19 PM
Bang! kwak zzr Idle Banter 9 05-11-07 11:03 PM
kill bill soundtrack bang bang hovis Idle Banter 8 22-05-07 03:53 PM
