Old 06-01-09, 12:14 PM   #1
thor
Default Why do my lights get brighter when I rev the engine?
Perhaps the battery is on it's last legs? I have some heated grips on, but that's it.
Also, The top half of the brake lights are dimmer than the bottom half. They also get dimmer when the indicators are on.
Any help gratefully received as always...
Old 06-01-09, 12:17 PM   #2
Warthog
Default Re: Why do my lights get brighter when I rev the engine?
I think it is a good thing, that's the test to see if the alternator and reg/rec are charging the battery.
Old 06-01-09, 12:20 PM   #3
SoulKiss
SoulKiss's Avatar
Which year do you have?
I believe that pre-k5 (or k6) pointies have a problem with the Rear light unit......
Old 06-01-09, 12:21 PM   #4
Stig
It's MAGIC
Old 06-01-09, 12:25 PM   #5
Stu
Trinity
Stu's Avatar
sounds fine to me
Old 06-01-09, 12:26 PM   #6
Ceri JC
Yes, my K4 had a dodgy rear light unit. It was very subtle (possibly would of passed an MOT even), but one of those things that once you noticed, couldn't help seeing. A replacement unit fixed the problem.
Old 06-01-09, 12:49 PM   #7
thor
Ok, I'm guessing a search will help here...?
K4 - I see
Originally Posted by BigApe View Post
It's MAGIC
Was that the only reason you replaced it? Was it expensive?
Thanks!
Old 06-01-09, 01:44 PM   #8
shifter
It's not a good thing. the regulator does exactly that, regulates the voltage. If your lights get brighter with the throttle then it's on its way out and will probably take the battery with it.
Old 06-01-09, 01:48 PM   #9
Dave20046
Dave20046's Avatar
Really?! Everybike I've ever owned has done this.
Old 06-01-09, 01:48 PM   #10
Lozzo
It's a sign from god that you are the new messiah. You should form your own cult religion based on nudity and free love.
Funny problems with engine speed and lights dimming Binky SV Talk, Tuning & Tweaking 6 15-07-08 08:20 AM
Brighter Bulbs What are the ones? k146 SV Talk, Tuning & Tweaking 56 11-12-07 01:58 PM
Brighter Bulbs k146 SV Talk, Tuning & Tweaking 31 22-08-07 04:59 PM
Brighter Lights echomadman SV Talk, Tuning & Tweaking 14 13-04-05 06:41 AM
Brighter Headlight Installation... MitchC SV Talk, Tuning & Tweaking 15 14-03-05 08:55 PM
