Old 04-07-17, 11:39 AM   #1
Lumpy
Default Loud tick noise and then stalling on tick over ??
Hi . Had a run out on Sunday bike was riding great but pulled up at lights and
It cut out ( never before ) . Started ok but revs dropping and a tick
Noise . It ticks and revs drop and then ok . I'm thinking could be plug leads
( new plugs in ) any thoughts
Cheersv
Old 04-07-17, 11:40 AM   #2
Lumpy
Default Re: Loud tick noise and then stalling on tick over ??
Sorry it's a 2000 curvey !
Old 04-07-17, 12:26 PM   #3
carbs needing balanced
camchain tensioner stuck
tickover needing adjusted
low oil, if its been run on low oil then engine will likely be toast.
Old 04-07-17, 02:31 PM   #4
Craig380
How long ago did you fit the new plugs? Are they tightened up snug, or could one have worked loose a little? Are the plug caps fitted tightly?
Old 04-07-17, 02:57 PM   #5
Lumpy
The plug and leads are the rought I'll be lookin first . Bike runs
And pulls fine at higher revs
I'll take a look tonight . Ta
Old 04-07-17, 03:15 PM   #6
SV650rules
vacuum leak, did any pipes get disturbed when fitting new plugs ? sometimes old pipes are OK until they get moved and then they leak.
2016 SV650 AL7
Old 04-07-17, 03:33 PM   #7
Lumpy
I'll check all tonight . The bike has only done
About 200 mile since strip down and cafe raced
One thing I do know the battery is a old one
Old 05-07-17, 09:22 AM   #8
Lumpy
Had a look last night but didn't have a lot of time .
Bike fired and tick over was fine until it got hot
Then was cuttin out when tickin over .
More investigation needed
Old 05-07-17, 11:59 AM   #9
turn the tickover up. should idle around 1400rpm.
Old 05-07-17, 01:50 PM   #10
Lumpy
I'll have a go! To me it sounds electrical
Something braking down . Like I said no problem when cold
bad tick over jon-northampton SV Talk, Tuning & Tweaking 3 14-04-15 09:10 PM
SV 650 K5 won't tick over GHOST123 SV Talk, Tuning & Tweaking 4 04-03-11 09:11 AM
Tick Over NAPA121 SV Talk, Tuning & Tweaking 10 02-11-06 09:47 AM
tick tick tick .... anna SV Talk, Tuning & Tweaking 18 26-08-06 03:31 PM
Bike fell over left side, tick tick noise when riding now?? jump SV Talk, Tuning & Tweaking 4 14-03-05 09:26 PM
