Old 02-12-17, 02:17 PM   #1
simon1
Default sv650 tick over
Hi
My sv650 k1 model is idling to fast....idle screw is adjusted...throttle is as closed as it can be,,,,,one thing I did was put my hand over the opening of the front carb,while engine was running...felt the suction,then fuel,then engine stopped due to flooding I assume?....did the same with the rear carb...felt the suction,then fuel..but the engine did not stop..could this suggest a air leak in the rear carb,making the tickover to high???
simon1 is offline   Reply With Quote
Old 02-12-17, 07:59 PM   #2
johnnyrod
johnnyrod's Avatar
Default Re: sv650 tick over
Are the carbs balanced, even roughly?
Old 02-12-17, 10:21 PM   #3
simon1
Hi,
No I have not balanced them.....why can this cause a fast idle?......got to say otherwise the bike goes well..no flat spots..starts fine etc
Thanks
Old 03-12-17, 11:47 AM   #4
R1ffR4ff
R1ffR4ff's Avatar
I think you are in the right direction with an Air-leak but also search the forum for problems with the Choke Plungers.I'm still pretty new to SVs but I think I've seen similar symptoms caused by them sticking.
Old 03-12-17, 05:56 PM   #5
Sir Trev
Sir Trev's Avatar
How old is the choke cable? They stick after a while and need replacing.
Mine started sticking intermittently which was a pain as you cannot tell if it's balanced right until you know the choke plungers are being returned properly.
Old 03-12-17, 07:36 PM   #6
simon1
Hi
Thanks for all the info......re choke....the wire is going all the back...but the choke could still be open?
Old 03-12-17, 08:09 PM   #7
simon1
I will change all my throttle ,choke cables all though they seem ok....one thing,are the naked model cables longer because they have the high bars??....
Old 03-12-17, 08:39 PM   #8
simon1
just one thing....when the engines warm and I pull out the choke the engine starts to die...due to being to rich??...so if the choke was stuck wouldn't this happen?
Old 04-12-17, 09:39 AM   #9
Originally Posted by simon1 View Post
Hi
It might be going all the way back at the bar, but it splits into two under the tank, so one of these could be causing your issue
Old 04-12-17, 01:17 PM   #10
mep
mep's Avatar
Some years ago I had an intermittent tick over problem with my Curvy. The main problem was the choke cable was sticking after the split for one of the cylinders so a new one sorted that. Also one of the carbs was not connected properly to the airbox too, which didn't help.
mep is offline   Reply With Quote
Loud tick noise and then stalling on tick over ?? Lumpy SV Talk, Tuning & Tweaking 9 05-07-17 01:50 PM
SV 650 K5 won't tick over GHOST123 SV Talk, Tuning & Tweaking 4 04-03-11 09:11 AM
Tick Over NAPA121 SV Talk, Tuning & Tweaking 10 02-11-06 09:47 AM
tick tick tick .... anna SV Talk, Tuning & Tweaking 18 26-08-06 03:31 PM
Bike fell over left side, tick tick noise when riding now?? jump SV Talk, Tuning & Tweaking 4 14-03-05 09:26 PM
