Old 10-01-20, 03:06 PM   #41
DamoK4
Default Re: Will an R1 front master cylinder fit?
Sorry, fixed it now
DamoK4 is offline   Reply With Quote
Old 10-01-20, 03:11 PM   #42
Chris_SVS
Chris_SVS's Avatar
Those need a wee clean
Chris_SVS is offline   Reply With Quote
Old 10-01-20, 03:31 PM   #43
DamoK4
when i took the pistons out they both came out together and i don't know which is which. will it matter?
Old 10-01-20, 03:36 PM   #44
Chris_SVS
Chris_SVS's Avatar
Nope
Old 10-01-20, 03:57 PM   #45
DamoK4
Cheers.
Just found that my master cylinder is an axial Nissin. Is this standard? The reservoir is pretty new so made me have a good look.
Is it worth changing these seals? Not removed anything yet apart from pads. They look pretty new and clean. The sliding pins seem a bit stiff
Old 10-01-20, 04:15 PM   #46
Chris_SVS
Chris_SVS's Avatar
I wouldn't take pistons out without changing seals, that's just me though.
Old 10-01-20, 04:21 PM   #47
DamoK4
I might as well. Having issues with the sliders not moving at the mo. Cant pull the sliding bit out, both sides are well and truly seized. Soaking in wd50 at the moment.
Old 10-01-20, 08:09 PM   #48
Dave20046
Dave20046's Avatar
As per Chris' comment. You may aswell change them, they're an unknown age and quality and they can look okay but have actually swollen - to me the dust seals look a bit gammy but that could just be the light/liquid on them. They'll always look fairly clean as they're submerged...see what you find behind them.
If you didn't before you will now! WD40 is pretty bad for them.
Which slider? The one at the top side of the caliper or pin?
Old 10-01-20, 08:27 PM   #49
SV650rules
WD40 is petroleum based and will swell and damage seals designed to work with brake fluid... but WD50 May be OK
2016 SV650 AL7
Old 10-01-20, 08:43 PM   #50
Chris_SVS
Chris_SVS's Avatar
A rebuild kit should include new rubbers, R clips, retainer pins anyway. When I rebuilt mine they required persuasion with a heavy device to break the salt
My 2015 Tracer 900 looked like this today with little more than a spray with cleaner and gentle scrubbing
Sv1000 Front Master Cylinder On SV 650? ryangarside SV Talk, Tuning & Tweaking 4 02-04-11 10:59 PM
Front master cylinder eviltwin Stuff Wanted 0 27-09-10 02:00 PM
Front master cylinder sniff Stuff Wanted 3 28-04-10 09:19 AM
Front master cylinder taggy Stuff Wanted 7 31-08-07 06:02 PM
R1/R6 Front master Cylinder jonnygman SV Talk, Tuning & Tweaking 6 29-04-07 01:10 PM
