Old 07-12-23, 02:22 PM   #11
glang
Default Re: Front fork Springs help
yes but to keep the shock in the correct position the first third of the spring should be used up with the weight of bike and rider (the same as if it was a linear spring) then after that the spring gets progressively stiffer so compression should be less for a given load. I think its why they came up with progressives, to limit travel...
Old 08-12-23, 06:21 PM   #12
Sir Trev
Sir Trev's Avatar
Plus, if you have budget springs as OEM, anything is a vast improvement, and without trying both linear and progressive side by side, most would not notice the difference.
I've had Progressives installed on two bikes now and been very happy with both.
Old 08-12-23, 07:19 PM   #13
glang
Well if your sag is correct with the OEM spring I dont think you can get much better no matter how much you spend on a replacement. Going to a linear would mean that under a given force the shock will travel further and make the sensation a little smoother because energy absorption will be less abrupt....
Old 09-12-23, 07:41 PM   #14
Suzuki-Ste
Junior Member
Suzuki-Ste's Avatar
Thanks everyone for all the info will send them to a suspension bike shop see if they can sort it as glang said bouncy bouncy not to soft lol.
may try some new oil a bit heaver than stock.
SV650 Gen 2 04
DL650 Gen 2 11
SV660 Gen 3 AL6
SV650 Gen 3 AL9
Just got to Love a V-Twin
Suzuki-Ste is offline   Reply With Quote
Old 11-12-23, 06:02 PM   #15
EssEllTwo
If you need spacers let me know, I have plenty spare from when I did my springs and was trying different lengths. Or buy yourself some PVC pipe and make your own (but then like me you'll still have 2m of it kicking around the garage)
EssEllTwo is offline   Reply With Quote
Old 13-12-23, 11:57 AM   #16
NedSVS
Did you try the Racetech spring rate calculator I pointed you to? It would give you a good idea of how close, or far out, the standard springs are for your weight and riding style.
best front fork springs? Gaz.sv650 SV Talk, Tuning & Tweaking 53 03-09-15 08:09 PM
Front Fork Springs And Oil Help achapman01 SV Talk, Tuning & Tweaking 16 03-09-10 10:11 PM
Front Fork springs stev SV Ecosse 7 30-04-06 10:29 PM
front fork springs mata15 Ancillaries 1 13-11-05 02:25 PM
Front fork springs falc SV Talk, Tuning & Tweaking 14 15-07-05 02:13 PM
