10-04-06, 02:47 PM | #1 |
K3 rear wheel bearing sizes
What are they please so i can order some for my curvey wheel.
Cheers Oh...Where is the best place to get em from? |
10-04-06, 02:52 PM | #2 |
I don't know the codes for them mate,(But if you gently tap the existing one's out using a suitable drift and hammer...you will be able to read the engraved code on them) Your smartest bet is to source them through a local Engineer suppliers or bearing factor. The codes are used to tally up the right item no matter who the maker is.
With a bit of basic skill there is no big deal to removal and replacement of wheel bearings.Good luck. Avoid Suzuki prices if at all possible. |
10-04-06, 03:41 PM | #3 | |
10-04-06, 05:34 PM | #4 |
Got my wheel bearings for my k3 from this company, a lot cheaper than suzuki
http://www.thebearingshop.com |
10-04-06, 05:49 PM | #5 |
Good point,is the axle bolt the same diameter on both models?
10-04-06, 06:01 PM | #6 | |
10-04-06, 06:13 PM | #7 | |
Re: K3 rear wheel bearing sizes
Cush Drive 25x62x17 Cheers Ben |
10-04-06, 06:26 PM | #8 | ||
A 6204, a 6204 2RS and a 6204 ZZ. Whats the difference and wat one do i need? |
10-04-06, 06:35 PM | #9 |
The Sick Man
2RS - 2 rubber seals (withstand water getting into the bearing)
ZZ - Double Metal Shield (does not withstand water) AFAIK From what i have read. 2RS are the ones to go for i was told when i needed to get mine.
OTR: KTM 690 Duke R 2015 Full Akro SIDELINE: Kwak ZX636 A1P 2002, Red, R&G's, Yoshi, Double Bubble Screen GONE: Kwak ZX-7R P1, Full Akro, Undertray, Screen GONE: SV650S K2 Very Bruised & Without Fairing, Motovation Frame Sliders, R&G Ally Sprocket Toe Protector, HEL 2 Line Setup, GSXR K1 600 RWU Forks, Barnett Clutch & Springs, Penske 8981 Shock, Gilles Ti Rearsets, Steel Barends, Scottoiler, AFAM Chain & Sprockets, Twin FIAMM Horns, Skidmarx Bellypan, Full Micron Zeta Steel System, Cut down undertay. Forum Problems & Information / Site Suggestions |
10-04-06, 06:37 PM | #10 |
Just go for 2rs, this is just what type of seals are fitted (if at all).
2RS is 2 rubber seals ZZ is metal sheilds PDQ have them in stock, most dealers should have as just about all honda's and some Kwaks have 6204's in their front wheels |
Wheel Bearing Inner Race Removal: | MrMessy | Bikes - Talk & Issues | 11 | 15-11-08 10:04 PM |
Front wheel bearing shot? | DanAbnormal | Bikes - Talk & Issues | 4 | 18-05-08 10:01 PM |
Wheel sizes | stuartyboy | SV Talk, Tuning & Tweaking | 11 | 20-10-06 04:09 PM |
Rear Wheel Bearing Removal | TSM | SV Talk, Tuning & Tweaking | 10 | 20-03-06 10:54 AM |
Wheel bearing grease and filter oil | big twin grin | SV Talk, Tuning & Tweaking | 2 | 05-03-06 10:16 PM |
