Old 22-06-06, 12:12 PM   #1
andyaikido
Default Rear Brake Adjustment
I've got Gilles rearsets on my K5 but can't get the rear brake pedal to sit low enough.
As it is its uncomfortable to lift my foot onto and then the brake's too sharp, either brake on or brake off.
I can't adjust it in the normal way as it is as low as it can be without the brake binding on.
Only solution i can think of is if the part that has the thread and locking nut (sorry, don't know what its called) is shorter on another Suzuki model and can be swapped over.
Anyone done this / know if its possible?
Old 22-06-06, 01:12 PM   #2
Chop a bit off the bottom of the "bolt"?
Old 22-06-06, 02:56 PM   #3
andyaikido
I would then have to drill a hole for the pin to go through. How hard is it to drill through a round object? Bear in mind i don't have any fancy tools.
Old 22-06-06, 03:05 PM   #4
Quite hard Don't think mine has a cotter pin though, just 2 nuts.
Old 22-06-06, 07:03 PM   #5
andyaikido
Hmmm... my mates got a Gixer. Might see if his is shorter
Old 22-06-06, 08:21 PM   #6
If there's no adjustment left then the adjuster needs to be shorter, so yes.
Old 23-06-06, 05:33 PM   #7
Robw#70
And fit a Nylock nut instead of the split pin
zx600r rear 'break' question, (rear brake). steve.s Bikes - Talk & Issues 6 19-02-09 07:50 PM
Cleaning all around the rear wheel / swingarm / rear brake caliper Camel SV Talk, Tuning & Tweaking 12 28-04-08 02:00 PM
C Spanner - Rear Preload Adjustment jessie SV Talk, Tuning & Tweaking 17 10-08-07 09:59 PM
Brake lever adjustment jamesw1024 SV Talk, Tuning & Tweaking 4 31-07-07 03:01 PM
Brake light not working when rear brake is used.. StreetHawk SV Talk, Tuning & Tweaking 10 16-04-07 03:40 AM
