Old 05-07-18, 05:11 AM   #1
mnikodemus
Default Throttle Valve Seizing
Hey Guys,
I have an 04 2nd gen bike. Tried to start it a few months ago, but it had a completely seized twist throttle. Got around to investigate the issue- removed the throttle tube, checked the cables, removed the air box.
The throttle body linkage itself (which connects the throttle valves of both cylinders) is hard to actuate. I worked it open and closed several times, and it helped a little. It’s still too hard to open with the cable though.
Anybody have any ideas?
It was running a couple months earlier, I just let it idle to charge the battery.
I also found a large rodent nest on top of the air filter in the air box. Full of insulation. I didn’t see anything on the other side though.
Old 05-07-18, 06:50 AM   #2
Craig380
Default Re: Throttle Valve Seizing
Hose all the pivot points on both throttle bodies with WD40, leave alone for a few house, hose them again, then try moving them and see if they've freed up. It's likely to be a buildup of road crud that's caused them to stick.
Make sure they move freely before trying to ride the bike though, you don't want the throttle sticking open when you're on the road.
Old 05-07-18, 10:29 PM   #3
mnikodemus
Thanks Craig! Hosed everything down with WD40 today. It’s operating better, but still sticks at WOT sometimes.
I’ll let it sit overnight, see how it is tomorrow.
I’m thinking maybe I should just go ahead and replace the throttle cables, since I already have most of it apart...
Old 06-07-18, 06:47 AM   #4
Craig380
Probably a good idea to do that while it's an easy job. Just in case the cables are stiff / sticky
Old 08-07-18, 03:56 AM   #5
mnikodemus
Ended up spraying another dose of WD40 on, it is working fine now. No more sticking! Bought one of the WD40 cans with the flex straw- if it sticks again in the future I can reach it without having to take everything apart again.
Old 08-07-18, 05:29 PM   #6
tom_e
Put some proper lubricant on it now you've cleaned it with WD40, even just some light oil will be better than nothing.
tom_e is offline   Reply With Quote
Old 08-07-18, 06:14 PM   #7
SV650rules
+1
Original WD40 makes a good degreaser, cleaner and water dispersing, but it is not a lubricant (although WD do now make lubricants). It dries to a gummy lacquer that attracts dirt. Put some PTFE ( Teflon ) containing lubricant on throttle now, I used 3 in 1 advanced PTFE oil on a padlock on our side gate about 5 years ago and it has been perfect ever since despite being out in all weathers.
2016 SV650 AL7
Old 09-07-18, 12:14 AM   #8
mnikodemus
Yeah agreed that the original WD40 is a terrible lubricant. I just used some wax-based chain lube, it’s all I had.
Throttle plate / butterfly valve zedi SV Talk, Tuning & Tweaking 11 03-06-17 08:18 PM
Secondary Throttle Valve Removal Stuart42 SV Talk, Tuning & Tweaking 2 26-01-15 09:27 AM
removing secondary throttle valve's svsdutch SV Talk, Tuning & Tweaking 2 14-05-08 10:43 AM
Throttle Valve Synchronisation - help! Aidan SV Talk, Tuning & Tweaking 11 05-11-07 08:20 PM
Throttle valve link arms yorkie_chris SV Talk, Tuning & Tweaking 4 19-08-07 06:36 AM
