Old 30-07-18, 10:24 PM   #1
AnActualUnicorn
Default Poor running after cam chain swap
So, put simply, I've just replaced my cam chains and put everything back together and now it's not running right.
Before it ran fine (aside from cam chain noise) but now... Not so much.
I've triple checked the cam timing, seems to be fine, turned the crank 360° between cylinders, tried old and new plugs (spark seems fine with plugs out) and valve clearances seem to be within spec. I'm at a loss as to what it could be so any ideas would be appreciated. Exhaust sound is very uneven, and that whistling sound is fairly well pronounced
https://youtu.be/7yZT17XwvFI
Old 31-07-18, 12:04 AM   #2
squirrel_hunter
squirrel_hunter's Avatar
Default Re: Poor running after cam chain swap
The first thing I'd be interested in is what was dropping into your drain bucket of oil?
Next I'd look at the injectors, are the on properly? Same question for the airbox and suchlike, what did you remove as part of the process, might help to track the problem down?
"A little enthusiastic?"
SH2 | 2MA | GROM | YSR
Old 31-07-18, 05:51 AM   #3
AnActualUnicorn
I haven't got the coolant hoses tightened, it's just water. I did have the throttle bodies off but I didn't take the injectors out
Old 31-07-18, 09:33 AM   #4
Craig380
I can't hear the whistling sound but it sounds to me like the throttle bodies might need balancing, or maybe there's a slight air leak from an airbox or TB mounting rubber. Are all the rubber sealing caps OK on the TBs?
Old 31-07-18, 09:50 PM   #5
squirrel_hunter
Throttle bodies/ injectors, are they seated correctly with no air leaks?
And why were you swapping the cam chains?
Are you running the standard cam chain tensioners?
What did you remove and replace as part of the process?
Very poor running, help! volvoboy73 SV Talk, Tuning & Tweaking 38 10-06-17 04:12 PM
Poor running after derestriction. coopesh56 SV Talk, Tuning & Tweaking 16 08-05-12 12:03 PM
Poor Running SV Binky Bikes - Talk & Issues 0 22-02-09 02:13 PM
Poor running. gerbrox Bikes - Talk & Issues 2 04-02-09 11:01 PM
Poor Running Daz Wood SV Talk, Tuning & Tweaking 1 07-07-05 11:09 PM
