Mini-Twins Goto Minitwins Official Site
Old 05-01-10, 10:46 AM   #1
SV650Racer
Exclamation Important - add anti freeze now if you havent!
If your bike has only water in the system then it would be a very good idea to drain this out for a neat anti freeze/coolant mix.
We have had 3 racebikes in the past week come in that are frozen up. Luckily two have just popped their core plugs. One has cracked the head sadly.
If when you remove the water you find its already gone to slush then ideally you need to check that its not popped its core (freeze) plugs. The only safe way of doing this is to wip the cam cover off and check. You can start it and see if you get water in the oil but the only problem is if the core plug has popped then it could travel down into the engine and munch something expensive.
I reckon alot of bikes will suffer this winter due to it being so cold for so long.
Hope this helps.
Sarah
Old 05-01-10, 10:10 PM   #2
Berlin
Default Re: Important - add anti freeze now if you havent!
I thought it was standard practice to drain race bikes for the winter?
Its a smaller job than flushing an engine filled with Antifreeze.
C
Old 06-01-10, 04:07 PM   #3
Shellywoozle
Shellywoozle's Avatar
Oohhh mine is sitting in the garage, was gonna put battery on tonight and start her up ..... will this be a bad idea ???
Old 06-01-10, 04:12 PM   #4
Alpinestarhero
Shell, your road bike will probably have anti-freeze in it anyway Racers may not particularly fill their cooling systems up with liquid containing anti-freeze
Old 06-01-10, 04:55 PM   #5
flymo
flymo's Avatar
Yeah, I drained mine just before christmas. also left a small cup of water next to the bike in the garage so I could check for freezing. Might just antifreeze and refill anyway to be on the safe side, its easy enough to drain again in March.
Old 06-01-10, 07:09 PM   #6
fastdruid
fastdruid's Avatar
More to the point IIRC the ACU regs state that there should not be anti-freeze in them.
Druid
Old 06-01-10, 07:59 PM   #7
Alpinestarhero
Druid
ah, that must be due to antifreeze being quite a slippery substance when spread over...lets say...tarmac...?
Old 06-01-10, 08:00 PM   #8
Shellywoozle
It belongs to me it's bound to break everythin I touch at the mo is breaking
I think I will start it when it not so cold .... minus 9 tonight ..... even Samsons paws froze today and he refused to walk
Old 07-01-10, 02:34 PM   #9
SV650Racer
Druid
Correct. But if your not racing it then pop some in. I leave it in all my bikes right up until the evening of the first meeting. Have seen bikes freeze overnight at the circuit too. Its going to be a common problem this winter sadly for some.
Old 07-01-10, 06:08 PM   #10
hardhat_harry
Mines dozing in a heated garage but Im may just pop some in just to be on the same side
burn or freeze? GeneticBubble Idle Banter 23 02-07-09 06:20 PM
Can different types/brands of anti-freeze be mixed? monkey SV Talk, Tuning & Tweaking 8 06-05-09 08:31 PM
Anti British and anti American threads - crass and boring Ed Idle Banter 40 13-06-06 06:08 PM
Speedo freeze Samurai Bikes - Talk & Issues 2 17-01-06 09:34 PM
if you havent got a race can DO IT NOW FORGET THE COST!! kwak zzr Exhausts 14 05-04-05 09:42 PM
