Old 16-06-09, 09:37 PM   #11
flymo
flymo's Avatar
Default Re: rear axel nut torque
Right I've just checked my Haynes manual which is for years 99 to 05
At the beginning of chapter 1 - Routine maintenance and servicing, it has a list of torque settings. For the rear axle nut it has 65 Nm. It does not specify between the different models
BUT.........
At the beginning of chapter 7 - Brakes, wheels and tyres, it also has a list of torque settings......
Rear wheel axle nut
X, Y, K1 and K2 models ............65 Nm
K3, K4 and K5 models ............100 Nm
I don't know why one is called rear axle nut, and one is rear wheel axle nut, but it looks like they have made a mistake in chapter 1 by not specifying the different models. I wish they would make a manual for the curvy and one for the pointy to avoid confusion.
That must be what I found in mine....its actually pretty dangerous, you could quite happily follow the figures in chapter 1 and think you had done it correctly. A difference of 35Nm is alot of error though.
I would hope that you would notice pretty quickly if it came loose though.
Old 16-06-09, 10:47 PM   #12
rockster
I noticed this error in the haynes manual too. Had me confused for a while but the k3 owner's manual says 100nm
Naked K3. Mods: Little thermometer thing stuck on with a bit o' velcro
rockster is offline   Reply With Quote
Old 16-06-09, 11:01 PM   #13
lazymanc
Probably when the rear wheel comes past you under braking
lazymanc is offline   Reply With Quote
Old 17-06-09, 08:41 AM   #14
DaveP
Unless you have a k3 bike with a curvy manual liek me!! Fecking dealers!!
Old 17-09-11, 03:55 PM   #15
trail guru
Default Re: rear axle nut torque?
DarrenSV650S is right re the error in the Haynes manual. Chapter 1, page 2 under Servcing Specs has 65Nm for both models but it should read: 65Nm up to 02, 100Nm 03 on.
Old 18-09-11, 12:04 AM   #16
the torque setting for the rear nut is tight
before nyloc nuts people used castellated nuts which required you to either tighten it more or slacken it off to get the R clip on. i think that the US bikes are still the same. personally i think 100nm is way to tight.
Old 18-09-11, 02:41 AM   #17
Richie
fantabulas
Richie's Avatar
didn't we do this some time ago?
Rear wheel axle nut sweepdoggydog Stuff Wanted 0 25-04-09 07:47 PM
Rear axle nut alternatives? arcdef SV Talk, Tuning & Tweaking 11 08-04-09 03:03 PM
Stainless Rear Axle Spacers ukhammy For Sale - SV's and SV related items 12 25-03-09 09:18 PM
Rear Axle Torque Setting K6 Hardened Rider SV Talk, Tuning & Tweaking 3 01-09-08 09:51 AM
What is the size of the Rear Axle nut? mordecai SV Talk, Tuning & Tweaking 4 02-05-05 07:57 PM
