08-07-05, 02:07 PM | #1 |
exhaust studs?
Whilst cleaning my filthy downpipes, I tried to remove the corroded manifold nuts and the stud came out with it.
Is it ok to replace these with a length of stainless threaded bar? or should I buy new Suzuki mild stell studs? seeing as metre of stainless threaded bar is about £1
Not Grumpy, opinionated. |
08-07-05, 03:35 PM | #2 |
I've snapped stainless exhaust studs before. I'd just get OE stud from Slingers. Stainless can cause the ally head to corrode around it. Electrolytic corrosion or some such thing. Titanium on the other hand....
08-07-05, 10:26 PM | #3 |
NOT stainless
Don't do stainless. The reason being because of the heat involved the threads can "pick up " worse than mild steel, this rips the threads, make sure you use some copper grease when you put it back on to stop it siezing again. If you want to re-use your old stud put it in a vice protecting the threads using aluminium in the jaws and heat the nut up with a blow torch and remove whilst very hot. I do this a lot in my line of work.Stainless is great if no heat is involved.i.e anywhere else on the bike.
Broken exhaust studs | Bill.Cross | SV Talk, Tuning & Tweaking | 24 | 28-12-08 01:31 PM |
gasoline in my exhaust... fuel in my exhaust | mtb83201 | SV Talk, Tuning & Tweaking | 5 | 29-04-08 10:58 PM |
Exhaust Studs | New Leaf | SV Talk, Tuning & Tweaking | 9 | 09-07-07 07:35 AM |
Stainless steel exhaust studs?? | svrash | SV Talk, Tuning & Tweaking | 7 | 30-01-07 04:55 PM |
Exhaust Gasket and Studs | TSM | SV Talk, Tuning & Tweaking | 2 | 07-09-06 06:22 PM |
