Old 07-09-06, 03:09 PM   #1
TSM
The Sick Man
TSM's Avatar
Default Exhaust Gasket and Studs
What is the size of the exhaust gasket on the curvey engine, mine keeps leaking and i at the moment have to use exhaust sealent that only lasts a few weeks before going.
Ahh and a tip, to remove the studs on the heads, get two bolts the correct size to thread on the studd, tighten one against the other then undo the top one and it will lock against the bottom one causing the stud to come out. Then you can replace with hex headed bolts.
Old 07-09-06, 04:34 PM   #2
dirtydog
Knob faced knobster
dirtydog's Avatar
Default Re: Exhaust Gasket and Studs
Yeah that is a good tip and works most of the time, unless the inner bolt (closest the engine) strips the thread off the stud and then you cant get the flippin thing off
failing that find some one who will lend you a stud extractor or buy one from ARE or somewhere similar
2001 SV650 in shimmerin green, Not broken anymore
Old 07-09-06, 06:22 PM   #3
Can't remember the size... OEM's not expensive though.
Broken exhaust studs Bill.Cross SV Talk, Tuning & Tweaking 24 28-12-08 01:31 PM
Exhaust Studs New Leaf SV Talk, Tuning & Tweaking 9 09-07-07 07:35 AM
Stainless steel exhaust studs?? svrash SV Talk, Tuning & Tweaking 7 30-01-07 04:55 PM
Exhaust Gasket Sizes? andyaikido SV Talk, Tuning & Tweaking 3 14-02-06 05:47 PM
exhaust studs? timwilky SV Talk, Tuning & Tweaking 2 08-07-05 10:26 PM
