Old 09-01-17, 09:51 PM   #1
jagryan85
Default Phone Holder Recommendations
After a tried, tested & approved (by you guys) SV compatible phone holder for my 2001 curvy.
What do you guys recommend?
Ryan
Old 09-01-17, 09:52 PM   #2
Blapper
Blapper's Avatar
Default Re: Phone Holder Recommendations
I pop mine in the pocket of my Givi tank bag.
Old 09-01-17, 10:21 PM   #3
jagryan85
Hi, thanks.
It's so I can use my phone as a sat nav
Old 09-01-17, 10:46 PM   #4
Nobbylad
Nobbylad's Avatar
Originally Posted by jagryan85 View Post
Hi, thanks.
Earphones? Helps keep your eyes on the road too.
Old 09-01-17, 10:56 PM   #5
jagryan85
Yes and that too. Don't want to get tempted to blast the tunes though!
Still no ideas yet?
Old 09-01-17, 11:17 PM   #6
Nobbylad
Nobbylad's Avatar
I blast the tunes and, like others, have the phone in my bag. I use a Bluetooth receiver to plug my earphones in and control volume. The Bluetooth receiver is attached to the yoke using the 3m lock tape (like velvro but stronger and more reusable).
Old 09-01-17, 11:57 PM   #7
waynesdfell
It depends on your phone type. I have an IPhone and on 3 different bike have used a Tigra Phone case with a RAM 1" mount, they do them for different phones too. I usually have it central to my handle bars (to use as a satnav) but you can mount them almost anywhere.
I do have a spare fuel tank mount and one for mounting to somewhere like a mirror arm. if you're interested?
Wayne
Old 10-01-17, 08:03 AM   #8
carelesschucca
carelesschucca's Avatar
If you're phone is waterproof try Quad-lock, I know its designed for cycling, but it's strong, I can lift up 10kg of bicycle with it. I also use it as a mount on the Street.
It's not cheap but a brilliant little bit of kit...
Old 10-01-17, 03:28 PM   #9
Blapper
Blapper's Avatar
Hi, thanks.
Yeah, I have a pair of ultimate ears custom moulded earplugs that have lil' speakers in them I connect the jack to the phone and use google maps all the time. I can even use the touch screen through the clear pocket if needed (stopping to do that is recommended!). If its a long trip I turn the screen off as it is the screen that takes the big power on my phone.
HTH.
Old 10-01-17, 04:13 PM   #10
waynesdfell
For long journeys I'd suggest getting something like the Ultimate Addons phone charger system. Hook up to the bikes battery, has an in line fuse, big on/off button and the ends are interchangeable so you can hook up micro USB, iPhone satnav etc. Easy to install too
Ride safe
Quad Lock - Phone holder carelesschucca Bikes - Talk & Issues 5 16-11-15 01:16 PM
Phone holder fitting? Pointy. rapidgaz SV Talk, Tuning & Tweaking 5 17-09-14 12:26 PM
Phone / SatNav Holder? SIII Bikes - Talk & Issues 9 03-01-13 04:10 PM
TV/Broadband/phone BT/Sky/Virgin any recommendations? monkey Idle Banter 23 22-06-12 12:03 PM
Map holder[ Dicky Ticker Bikes - Talk & Issues 0 21-03-08 10:22 AM
