29-05-17, 07:35 PM | #1 |
sticker glue remover, solved
sesame seed oil. yup i shizz you not, it works great
i have tried all sorts of stuff including branded sticky stuff remover, isopropyl, petrol, paraffin, you name it i have tried it. just removed some sticker glue from a plastic spray bottle i wanted to use and i dont know why my brain said sesame seed oil but it did so me being me thought what the hell. poured some on a cloth and went to work. fekin superb, it glides and removes at the same time and is super quick unlike everything else i have tried which just makes the cloth stick and create a globby mess. |
29-05-17, 07:41 PM | #2 |
Re: sticker glue remover, solved
Did you try WD40, it is pants as a lubricant and does go like a sticky film if you leave it to dry, but as a solvent for sticky stuff of all descriptions, dead flies off paint etc it is unsurpassed.
In fact it is such a good solvent that it will effectively dissolve any lubricant out of whatever you spray it on and replace it with something that is as far from a lubricant as you can get. http://www.inspire21.com/stories/hel...s/UsesforWD-40 http://www.tutorialgeek.net/2011/01/...glue-with.html http://www.lifehacker.co.uk/2014/06/...ful-uses-wd-40
2016 SV650 AL7 Courage is resistance to fear, mastery of fear, not absence of fear - Mark Twain Last edited by SV650rules; 29-05-17 at 07:49 PM. |
29-05-17, 07:54 PM | #3 |
yup i have tried wd40 and others like 3in1. i have tried everything including mayonnaise, olive oil, vinegar, motor oil, brake cleaner etc.etc. but the sesame seed oil is the doggyzz doohdazzz.
30-05-17, 01:47 PM | #4 |
If that's what it can do, what does it do to your insides when you eat it
30-05-17, 02:35 PM | #5 |
dissolves any stickers you may have eaten
Silver SV650SK3, Fuel exhaust |
30-05-17, 08:08 PM | #6 |
Yeh I wish they would sell that glue they use on domestic bottles stickers.Sticks better than virtually anything else :O
Taking on-board what you posted I've just tried some cooking oil.Same affect.Takes off the glue easy.Been looking for something like this for ages so big thanks I tried all the stuff you had posted before the oil.I keep those spray bottles.I use one with a few squirts of Washing up liquid in it as a pre-soak for pots/pans and plates when I'm cooking.Makes cleaning them easy and saves loads on washing up liquid.I also use another of the same as a cheap none aggressive bike cleaner
"Stultus est sicut stultus facit" Last edited by R1ffR4ff; 30-05-17 at 08:24 PM. |
18-08-17, 01:00 PM | #7 |
I'd advise against soaking your bike with a solution like that for a long time, dishwashing liquids tend to have a large amount of salt in them and probably use charged surfactants that can behave as salts.
18-08-17, 01:37 PM | #8 | |
on any surface for long
25-08-17, 10:47 AM | #9 |
I discovered years ago that the best way of removing tar from car paintwork is to use butter on a cloth. Same idea as sesame oil but cheaper.
Some say the cup is half empty, while others say it is half full. However, both are wrong; the real problem is the cup is too big. Honda 125 CG blown engine Gone to the great mechanic in the sky Naked SV650 K3 in Silver |
25-08-17, 06:40 PM | #10 | |
The cat was many years ago now from my wife's friend's cat who had cute kittens , we had no cat before or since, mainly to help protect local wildlife and neighbours gardens - cats can cause an awful lot of friction between neighbours lol
Thread Tools | |
Ignition key wiggle solved | Bibio | Bikes - Talk & Issues | 21 | 09-07-15 08:19 PM |
Best paint remover | Winder | Idle Banter | 17 | 07-10-14 08:13 AM |
Dvd/Cd Scratch remover | daveyrach | Idle Banter | 10 | 26-02-13 02:37 PM |
Gorilla remover | Moo | Idle Banter | 11 | 06-11-06 10:07 PM |
Tar Remover... | 454697819 | Bikes - Talk & Issues | 9 | 24-11-05 11:41 AM |
