Old 13-08-17, 04:23 PM   #1
Mickle
Mickle's Avatar
Default Rotor bobbins
Just a quick one, is there any service work or testing ( other than visual inspection ) that we are supposed to be doing to the bobbins in floating disc brake rotors?
It should be remembered that there needs to be an element of challenge to a "short cut," otherwise it would just be "the way"
Mickle is offline   Reply With Quote
Old 13-08-17, 05:24 PM   #2
andy650
Default Re: Rotor bobbins
I always make sure mine spin reasonably freely, if not then I use a bolt/nut/washer and a little WD40 to clean them out and get them moving reasonably freely.
andy650 is offline   Reply With Quote
Old 13-08-17, 07:22 PM   #3
yokohama
As per the above. Usually do mine once a year.
https://www.youtube.com/watch?v=1qoPqN2GBdw is really helpful
Old 13-08-17, 08:20 PM   #4
Craig380
Brake cleaner is good for blasting out the crap before doing what's suggested in the video, and doesn't leave a residue.
Old 14-08-17, 10:34 AM   #5
shiftin_gear98
shiftin_gear98's Avatar
Mine have and will always be stuck solid. Until I replace the discs.
Crash bobbins SK3. str160 For Sale - SV's and SV related items 6 14-07-13 04:18 PM
R&G Bobbins Noble Ox Stuff Wanted 8 24-06-10 08:16 PM
VERY Cool Bar end and Bobbins bengrrr SV Talk, Tuning & Tweaking 13 09-03-10 06:49 AM
removing the generator rotor bolt/ rotor compatibilty? Andy Jeffries SV Talk, Tuning & Tweaking 0 05-08-09 12:00 PM
Levers, Bobbins, Bar End ibshort Stuff Wanted 4 18-03-09 09:01 PM
