Old 19-08-17, 08:25 AM   #1
650
650's Avatar
Default Bought a 650 hack
Something to leave up north for when I'm visiting friends and family. It's a 2000 plate, less than 8k on the clock. Got its battle wounds and needs a bloody good service etc... But anyway, I digress...
I have my full sv1000 front end sitting doing nothing and I'm thinking I'll just bolt it in. Am I right that I just need the special top bearings from TWF to bolt it in? I realise there's the speedo sensor etc but I'll deal with that separately.
Thanks in advance. I'll stick some photos up later when I'm off the mobile phone
93 VFR750 - WAY too many mods to list. Crashed
04 SV1000 - Bar end mirrors. Belly pan. Seat cowl. K4 GSXR600 K6 front end and custom top yoke. R6 Brembo MC
650 is offline   Reply With Quote
Old 19-08-17, 05:07 PM   #2
Default Re: Bought a 650 hack
you dont need to order the TWF bearing as you can get them here in this country much cheeper http://shop.marksman-ind.com/headrac...rings-13-c.asp you need to search for it. you need the top stem size and the headrace size
Old 19-08-17, 08:14 PM   #3
650
650's Avatar
All balls seem to offer both upper and lower bearings for this. I'm not really getting why everyone goes to TWF for the upper bearing tbh
Old 19-08-17, 08:23 PM   #4
people go to TWF due to them being the only people who done the bearing originally. its not just SV's that use this bearing, bandits and such like use it as well.
BTW the lower bearing is the same as the SV1000, gsxr etc.etc
Old 20-08-17, 04:19 PM   #5
650
650's Avatar
Yep, aware of the lower one. Is there still a demand for the 650 front end from the mini twin racers?
Old 21-08-17, 08:40 AM   #6
650
650's Avatar
Also, do 2nd gen SV shocks fit the 1st gens? I've bought an Ohlins - idea is to put it on my 1000 and put the 1000 shock on the curvy, if possible. Then put the 1000 front end on the curvy.
Old 21-08-17, 11:51 AM   #7
try searching for sv650 shock compatibility chart
winter hack Gaz.sv650 Stuff Wanted 0 19-08-11 12:01 AM
Nastiest hack? injury_ian Bikes - Talk & Issues 68 29-04-10 09:52 PM
USB hack? ooger Idle Banter 6 18-09-09 03:08 PM
Wanted: Hack yorkie_chris Idle Banter 16 16-10-07 06:58 PM
Winter Hack? Peter Henry Idle Banter 15 09-04-06 09:49 PM
