Old 05-11-09, 07:04 PM   #41
asteer17
Default Re: Datatool System 4 Red
If anyone has found how to access the dealer manual i would be very greatful for the info as i want to turn down the sensitivty of my datatool s4 red, its doing my nut in and the dealer who fitted it is 30-40 miles away
Old 06-08-21, 11:49 AM   #42
kawajoe
Junior Member
Hey
I know this is an old thread. Is TSR still active?
I understand security concerns but I'm struggling with repurposing my S3 red.
Used to have it on my old 125 but kept killing the battery. Long story short took it off and part ex the bike. Got a new bike and wanna repurpose the S4.
Only prob is some of my labels have detached from loom.
Any chance of some help? I think I'm 95% there just every combo of 4 wires in question keeps activating the alarm.
I hope someone can help and save me £350 for a new alarm to be fitted.
Joe
Sent from my IN2013 using Tapatalk
kawajoe is offline   Reply With Quote
Old 15-08-21, 10:40 AM   #43
kawajoe
Junior Member
Can anyone help?
Old 15-08-21, 12:16 PM   #44
Seeker
Seeker's Avatar
I don't have one but after a quick google others have said an established alarm installer will re-install it for about £80. Have you inquired about that possibility?
Datatool seem to have done a good job with their document security and I suppose it makes sense that even if a member or rider did know the wiring connections, he wouldn't want it published since it effectively reduces the security on his bike.
Finally, there seem to be a lot of Datatool owners complaining about their alarms (battery drains, and triggering unnecessarily) and asking how to remove it. Maybe a tracker (if you wanted to go electronic) or a disk lock might be another option? I find that car alarms go off so frequently, I often don't register them anymore.
Hope you get it sorted.
2016 SV650AL7
2023 GSX-8S
Old 16-08-21, 05:26 PM   #45
kawajoe
Junior Member
Thanks seeker. Every installer I have spoken to won't touch it. Only install alarms they supply!
Yes I understand the reluctance of people wanting to post publicly.
I have other security for the bike. It would just be nice when out on a meet knowing I can arm it and walk away. Yes I carry a disc lock under the seat always.
Thanks for the suggestions.
Old 17-08-21, 08:30 AM   #46
R1ffR4ff
R1ffR4ff's Avatar
I stick one of these under my rear seat along with a disc lock for the rear wheel/disc. Cheap and cheerful,
https://www.ebay.co.uk/itm/384147188171?hash=item5970f
£10 ish.
If you have a spare old Android phone you can install the free,"Globio" app,
https://play.google.com/store/apps/d...focus&hl=en_GB
with a cheap PAYG Sim card in the phone and set it up as a Tracker/Alarm which can call or text you if the bike is moved.
HTH
Old 17-08-21, 09:39 AM   #47
shiftin_gear98
shiftin_gear98's Avatar
Having had a Datatool alarm fail on my bike and the bike cut out mid corner at speed.
Not only was it a bum clenching moment, but I then had to push the ****er 3 miles to a relatives house.
It kept sporadically blowing the 30 amp fuse until I removed it.
Personally as it's off the bike I'd throw it in the bin, like I did with mine once I removed it.
Save yourself the hassle. Plus if you are half ar5e trying to install it yourself you could be opening up a massive can of electrical gremlins. Which will be a bitch to rectify.
My insurance went up a whole £9.00 when I told them it wasn't on anymore.
Currently driving a Corsa....
Old 23-09-21, 06:20 AM   #48
kawajoe
Junior Member
Thanks for your reply's guys. I already have a monimoto tracker on it. Just wanted that extra peace of mind. As working in central London ever deterrent helps.
I managed to work out the pin out. And will be fitting it this weekend. The problem turned out to be the fob! Somehow unpaired itself to the alarm.!!!!! just goes to show even if you see the red led light up when pressing the button, don't assume it's worked.
I'll get my local dealer repair it when the bike gets serviced next.
Datatool system 3 PIN? nobby SV Talk, Tuning & Tweaking 15 23-03-09 10:17 PM
datatool system 3 evertheoptimist SV Talk, Tuning & Tweaking 17 02-06-08 10:05 PM
DataTool System 3 Problems squirrel_hunter SV Talk, Tuning & Tweaking 9 25-04-08 08:39 PM
Datatool system 3 suzsv650 Bikes - Talk & Issues 1 04-07-07 01:26 PM
Datatool System 3 TSM SV Talk, Tuning & Tweaking 1 16-07-05 11:48 AM
