Old 08-12-05, 07:58 PM   #1
Tris
Default Ignition Controlled Terminal behind Dials
Having had the battery go flat on me a couple of times without any easily identified cause I've become a bit paranoid about it happening again. I've even taken to carrying my volt meter around with me so I can do a quick check.
It takes the whole edge off riding the bike.
So, I tracked down a LED voltage meter and want to hook it up to an ignition controlled source. A quick glance should make me
Is there an easy terminal there or do I need to take a wire back to the fuses?
Tris
Old 08-12-05, 08:09 PM   #2
TSM
The Sick Man
TSM's Avatar
It would be best to take it back to the fuse box. On the curveys there is a fat yellow wire from the fuse terminal which is switched.
I think on a twin you need more amps than the voltage for cranking the engine over.
Old 08-12-05, 08:17 PM   #3
svrash
Default Re: Ignition Controlled Terminal behind Dials
Where to old bean Been looking for a suitable one my self
Old 09-12-05, 07:38 AM   #4
Tris
There you go.
http://www.kuryakyn.com/products.asp?bn=metric&ci=2695
I got the black one and it looks fine only about 4mm long by 20mm wide. The postage & tax were a bit steep, but got it from the sates in 3 days!!
Tris
Old 09-12-05, 11:16 PM   #5
svrash
There you go.
Tris
4mm longs a bit small
So how much was it in total? All in
Old 11-12-05, 09:31 PM   #6
Tris
You're right, should read 40mm
Total cost $54
Tris
Dials light panosm SV Talk, Tuning & Tweaking 0 25-03-09 05:03 PM
Curvy - Ignition controlled electrical power source under pillion seat? TheStudent SV Talk, Tuning & Tweaking 12 02-10-08 06:01 PM
Dials iane Bikes - Talk & Issues 2 29-03-08 04:08 PM
Blue Dials nicollow SV Talk, Tuning & Tweaking 11 17-09-06 02:17 PM
Running in by controlled thrashing. Smiffy Bikes - Talk & Issues 3 18-05-06 08:11 PM
