Old 04-06-18, 06:44 PM   #1261
Default Re: What have you tinkered with today?
That's a neat solution there Bibs. Is it resting on the bottom yoke for stability?
Indicators going on that bracket too?
Old 04-06-18, 06:58 PM   #1262
yes its touching (slight miss calculation on my part) but its not for strength. the three fixing points are well enough with the square bar to make it rock solid.
yup indicators are going where they should just like OEM, i have 4 altered GSXR indicators (SV stalks but GSXR lenses) and got a nice fancy headlight lens
i like my big indicators just like my snow shovel.
Old 04-06-18, 07:58 PM   #1263
proze
That's a very tidy bracket, Bibio, very nice!
proze is offline   Reply With Quote
Old 05-06-18, 07:26 PM   #1264
fitted the yokes, bracket, forks, clocks, headlight bowl and sorted the wiring.
Old 05-06-18, 07:41 PM   #1265
proze
I sprayed my discs matte black. Then I cleaned all my fork internals, ready to go back together with new seals. Just need to make a pvc pipe seal driver.
Then I tore down the calipers. So bad. :/ One of the slide pins is completely stuck. So it's getting penetrating oil overnight. Otherwise I'm going to drill through the caliper and knock it out from behind. This is why regular maintenance is important!
Old 05-06-18, 08:15 PM   #1266
Looking forward to seeing the transformation of your Sv Bibs
Old 06-06-18, 09:23 PM   #1267
bike is almost done.
bars (drilled for the switchgear nibs), controls, headlight, front indicators, front wheel, front mudguard, brakes, mirrors and rearsets are all done.
bike started first press then petrol pipe popped off and sprayed petrol everywhere.. lol
still to do:
numberplate.
foot rests.
air box.
snagging:
front brake light wiring is not working (its not the switch).
wrong wattage bulbs in the indicators.
Old 07-06-18, 04:12 PM   #1268
bike almost finished. just waiting on PO delivering foot pegs and clutch switch..
Old 07-06-18, 08:30 PM   #1269
proze
PSA: Please, please, PLEASE service your brakes regularly! The previous owners of my SV did not do that. Ever, it seems. Sheesh, what a mission it's been cleaning up these calipers! I had to cut through the stuck slide pin and knock the halves out with a pencil chisel. And the calipers were caked thick with crud. They're lovely and shiny now, but it took about four hours!
So go outside right now and give your brakes some love.
Old 09-06-18, 05:43 PM   #1270
proze
Today I reassembled the calipers with nice Ti slide pins, EBC HH pads and lots of RRG, just for Bibio.
Then I rebuilt my forks.
Just got to spray the lower triple, cut down the Renthals and I can ride again!
Been got already today.. 454697819 Idle Banter 16 01-04-10 02:08 PM
Today DaveP The Border Patrol 4 02-03-10 10:52 AM
Going out today? tj2 The Border Patrol 1 01-06-09 09:22 PM
Today Tara Guildford Massive 14 02-06-08 11:56 AM
Today...... Caddy2000 Idle Banter 15 19-04-06 05:39 PM
