Old 21-06-05, 10:25 PM   #1
greeno76
Default Idle Speed Change (too high)
hi.
Does anyone have any logical explanation as to why my idle speed has inexplicably jumped to 3,000 rpm? I don't think it's a sticky choke as it doesn't run roughly,
Are my carbs knackered? Do I hear the sweet sound of my bank account emptying again?
Any suggestions welcomed!
Thanks
Jason
Old 21-06-05, 10:30 PM   #2
irl_dar
on the TL there is a throttle stop and if its set wrong it pushes the throttle lever beside the throttle boides and it revs to high,
now im not sure about the sv but im sure it might be something simular..
or maybe your choke cable needs adjusting..
easy jobs
cheers
dar
Old 22-06-05, 12:04 AM   #3
weegaz22
get the tank up and have a look around, push back the slides in the carbs and see if the butterflies are opened, check the cables
Old 22-06-05, 08:18 AM   #4
greeno76
Will do.
Thanks
J
Old 22-06-05, 08:23 AM   #5
Viney
Your choke cable could be knackered. Does it run ok othe than that?
As said, pop the tank up, give everything a good clean and lube
High Idle '02 SV650 motoyank SV Talk, Tuning & Tweaking 3 10-04-09 05:56 PM
'03 sv high idle issues crojack SV Talk, Tuning & Tweaking 3 01-10-08 02:57 PM
High idle when warm K2 lpjones SV Talk, Tuning & Tweaking 3 22-09-08 11:02 AM
High Idle Speed after 15mins riding kevmunro SV Talk, Tuning & Tweaking 4 22-04-08 09:08 PM
HOW to change idle speed andygib SV Talk, Tuning & Tweaking 4 31-01-07 04:09 PM
