Old 19-12-07, 06:01 PM   #1
HopefullySoon
Default Spark Plug Caps
Hi
I have got a mis-fire on the front cylinder , new plug , plenty of fresh go go juice . I have changed coils round and still got it so im recconing on it being cap/HT lead having seen better days .
Can anyone give me the NGK code for the pattern part . The 15 quid suzuki option is not appealing (**** Turpin had the decency to wear a mask ! )
TIA
Hopefully Soon
Old 19-12-07, 07:47 PM   #2
Biker Biggles
Biker Biggles's Avatar
Default Re: Spark Plug Caps
Also try cheching your loom for chaffing.SVs have a couple of pinch points under the riders seat where the bolts go through,and under the rear seat where the loom kinks around a bit of subframe.Inside the loom is a wire that goes from the coil to the ECU or whatever it is in the tailpiece.If that has an intermittant short in it you can get strange ignition faults.
Spark plug change - how? SV-net SV Talk, Tuning & Tweaking 21 11-05-13 04:08 PM
Removing coils/plug caps Whitty SV Talk, Tuning & Tweaking 2 16-10-07 06:06 PM
Spark plug wrench localhost SV Talk, Tuning & Tweaking 15 24-03-06 02:21 AM
Spark Plug Changing - Help Please jeremysilver75 SV Talk, Tuning & Tweaking 1 05-09-05 04:08 PM
Replacement plug caps wanted. Smiler SV Talk, Tuning & Tweaking 1 03-05-05 07:49 PM
