Old 10-02-18, 05:46 PM   #1141
DomP
Default Re: What have you tinkered with today?
Did the world's longest oil and filter change on my Daytona, be rude not to clean the engine up and wash the inside of the fairings plus a wipe around with Acf50 while I'm at it.
Sent from my SM-G903F using Tapatalk
Black 2010 SV650S Fully faired
White 2011 YZF R125 sold
DomP is offline   Reply With Quote
Old 10-02-18, 08:04 PM   #1142
admin
John T
admin's Avatar
Minor tinkering on the VFR today. Heat shield back in place and checked every electrical connector. Electrical problems are the vfr's Achilles heal.
Old 12-02-18, 02:25 PM   #1143
Ran some fresh fuel treated with Redex through the system, and removed the rear carb choke plunger.
Looks like I'll be needing a new choke cable, as this ones very sticky & gritty, but a bit of lube has helped a bit.
Glad I'd swapped the choke plunger screws for allen headed ones, a doddle to remove now
Old 12-02-18, 03:16 PM   #1144
R1ffR4ff
R1ffR4ff's Avatar
What size are the Allen screws if you don't mind
M3?
Old 12-02-18, 05:35 PM   #1145
M3?
The right sized ones that came out of my stainless selection
Pretty sure it's M3 X 10
Old 15-02-18, 07:05 PM   #1146
Toooldtodie
Toooldtodie's Avatar
Changed the radiator and fitted a radiator guard to new one. Cleaned front calipers and rear fitted with new pads, tensioned chain (new), checked tyre pressures, changed the oil... bike is now like Trigger's broom.
Thought I was in a bad mood, but it's been 30 years now, so I suppose it's just who I am.
05 SV650s now with proper suspension, hurrah!
Toooldtodie is offline   Reply With Quote
Old 16-02-18, 10:23 AM   #1147
R1ffR4ff
R1ffR4ff's Avatar
Took my 1999 Curvy for MOT.Clean pass,no advisories
Old 16-02-18, 02:44 PM   #1148
timwilky
timwilky's Avatar
None bike related tinkering.
Got a couple of sonoff devices, flashed them with Tasmato firmware, set up a MQTT broker, a small web server with PHP to talk MQTT, IFTTT to talk to the web server and.....
Hey Google, turn on the patio lights!
Then stuck openhab onto that server so I can now turn devices on/off from the phone as well!
Oh, the firewall that reverse proxies the IFTTT connection enforces encryption, the MQTT front end web site requires authentication. I also embed a key requirement. So reasonably secure.
The openhab is only accessible through a VPN outside of home so again reasonable secure. Lazy days ahead as I get smarter.
Not Grumpy, opinionated.
Old 16-02-18, 03:20 PM   #1149
ophic
ophic's Avatar
That's not tinkering, Tim. That's architecture.
Silver SV650SK3, Fuel exhaust
Old 16-02-18, 04:08 PM   #1150
Teejayexc
Teejayexc's Avatar
Pardon
Teejayexc is offline   Reply With Quote
Been got already today.. 454697819 Idle Banter 16 01-04-10 02:08 PM
Today DaveP The Border Patrol 4 02-03-10 10:52 AM
Going out today? tj2 The Border Patrol 1 01-06-09 09:22 PM
Today Tara Guildford Massive 14 02-06-08 11:56 AM
Today...... Caddy2000 Idle Banter 15 19-04-06 05:39 PM
