Old 25-02-21, 07:43 AM   #2121
Seeker
Seeker's Avatar
Default Re: What have you tinkered with today?
Originally Posted by Adam Ef View Post
So service manual states resistance on the stator should be 0.5 to 1.25 ohms each coil. I'm getting 1.5 , 1.5 and 1.6 on each of the three coils. Is that a sign it gone then? Something is definitely up although it all looks fine.
that looks ok - does your meter read 0 when probes are shorted? The 3 phases are similar in value, you'd be looking for a wildly different value on 1 phase if there was a problem. Does it read infinite to ground?
Does the rotor try and aggressively steal screwdrivers ie a strong magnet. The magnets may be visible - if so are they all in place? (some have a cover to stop them falling out of place)
Some early ignitions (CDI type) can cause a dvm to have erratic readings.
2016 SV650AL7
2023 GSX-8S
Old 25-02-21, 08:31 AM   #2122
admin
John T
admin's Avatar
That resistance is slightly high but at least they're all the same.
I found this useful
https://www.aberdeenbikers.co.uk/mot...gnosis-checks/
Old 25-02-21, 01:13 PM   #2123
Adam Ef
Adam Ef's Avatar
All the same but all higher than Suzuki say is acceptable. Would make sense as it heats up that the resistance gets even higher and charging system goes kaput. It would also explain why I could only get home the other day by revving the crap out of the bike.. causing it to crank out some power to recharge the system, otherwise it stalled. Readings at the battery with the engine running are low and only just up to 13 volts-ish with the revs held high.
Past:
Old 25-02-21, 01:15 PM   #2124
Adam Ef
Adam Ef's Avatar
+ Going to wire the reg rec straight to the battery as apparently the wiring saps a lot of voltage. Another common problem and common mod on the DRZ.
This bike is now competing with the amount of mods and fixes I did on my SV!
Past:
Old 25-02-21, 01:30 PM   #2125
BoltonSte
When the stator in the street went, it was at high temp. It would only crank or a couple of cycles. When I left it to cool it would fire up as normal.
I can't remember the numbers, although I'm pretty sure I had on phase a fair way out and was still insulated to earth.
Had an SV or three.
Street triple R - gone but not forgotten.
Now trying the lunacy that is KTM with a Superduke GT. for the pillion capability of course.
BoltonSte is offline   Reply With Quote
Old 25-02-21, 06:12 PM   #2126
svenrico
svenrico's Avatar
I had a Kawasaki Vulcan 900 classic that made a screeching/wailing sort of noise occasionally when setting off. It was diagnosed by a dealer as a faulty stator and they fitted a reconditioned stator but it still kept doing it although it never affected performance or anything else. It remained a mystery.
Just thought I would mention it.
svenrico is offline   Reply With Quote
Old 25-02-21, 06:22 PM   #2127
DJ123
DJ123's Avatar
More trailer painting this week - Giving the mudguards a fresh lick of paint, and adding some reflective stickers so it stands out more.
BMW F800ST
Old 26-02-21, 03:45 PM   #2128
admin
John T
admin's Avatar
More work on the VFR today. One of the bolts attaching the right hand caliper had seized. I'd previously tried to get it out using heat and an impact gun with no luck so I left it for the winter service.
It's not your standard fitment as it connects to a secondary master cylinder as this bike has combined brakes. I tried the impact gun again but it still wouldn't shift. So out with the angle grinder and chopped the captive nut up. That got it off. I then replaced the parts with items I'd already bought.
The other bolt in the photo is from the bl**dy mudguard. Despite copious amounts of antiseize they still stick and the allen head just chews up.
Fixed
Old 27-02-21, 03:16 PM   #2129
DJ123
DJ123's Avatar
Bike trailer is all back together now. Until i get around to checking a potential wheel bearing replacement.
BMW F800ST
Old 27-02-21, 09:46 PM   #2130
Adam Ef
Adam Ef's Avatar
Swapping out the DRZ stator. Also rebuilding the carb, again with new jets etc. Removed the pair system. Making up a blanking plate to replace it. Finally creating a loom to go straight from reg/rec to the battery to improve charging voltage by bypassing all the unneccessary stuff that saps power inbetween. A busy day.
Past:
Been got already today.. 454697819 Idle Banter 16 01-04-10 02:08 PM
Today DaveP The Border Patrol 4 02-03-10 10:52 AM
Going out today? tj2 The Border Patrol 1 01-06-09 09:22 PM
Today Tara Guildford Massive 14 02-06-08 11:56 AM
Today...... Caddy2000 Idle Banter 15 19-04-06 05:39 PM
