Old 15-04-05, 11:10 AM   #1
BillyC
BillyC's Avatar
Default Shocks...
Here we go again... sorry
I'm contemplating the GSXR shock upgrade. Most people seem to have gone for a Gixxer 1000 shock, from something like a K3.
I've an idea, but am looking for clarification; but is this preferable over a Gixxer 600 shock for the SV? If so, why? Please explain.
I guess it does come down to weight, of which I have plenty.
Old 15-04-05, 11:22 AM   #2
Cloggsy
Default Re: Shocks...
This might answer your question... Maybe
Old 15-04-05, 01:21 PM   #3
BillyC
BillyC's Avatar
Okay... so basically the GSXR 600 spring is softer than the existing K3 spring
And being on the heavy side... something a little harder is preferable - hence the GSXR 1000 popularity.
I've got my eye on a GSXR1000K3 shock at the moment...
Old 15-04-05, 01:32 PM   #4
mysteryjimbo
I've got a kwak shock which is a pretty good fit
Old 15-04-05, 03:55 PM   #5
philc2000
It ain't that much harder than what you've already got on the SV - although it is fully adjustable - I've left mine on stock as I'm not exactly heavy (11.5st/75kg).
Old 15-04-05, 04:05 PM   #6
BillyC
BillyC's Avatar
[quote="philc2000"]
Well, I am quite heavy - and would expect to be in the 13.5-14st category once I sort myself out again.
The stock settings on the SV shock are positively crap, and at the moment I have to have it one away from maximum preload. Any harder, and the shock has practically no travel - while maintaining the the same damping rate.
So... there's no point me going to a softer spring, and even though as you say the Thou's one isn't much harder - I'm sure it'll make all the difference.
Old 15-04-05, 05:00 PM   #7
norvidick
there is an alternativ you can do the same as I did that is fit a shock from a yamaha trx850 as they had ohlins fitted fully adjustable and that works realy well
Old 15-04-05, 06:54 PM   #8
Cloggsy
I got mine for £27
Old 15-04-05, 07:42 PM   #9
Richie
fantabulas
Richie's Avatar
For the Bigger chap's such as myself 14 stone-ish theres a ZXR636 shocker on ebay
look Here for more info...
My Flickr photos
Old 17-04-05, 05:55 PM   #10
BillyC
BillyC's Avatar
Well... looks like I've got one!
shocks socommk23 Bikes - Talk & Issues 6 20-01-07 04:09 PM
compatible shocks Stormspiel SV Talk, Tuning & Tweaking 23 27-09-06 12:42 PM
Do K4 shocks fit K3 tomjones2 SV Talk, Tuning & Tweaking 2 15-07-06 11:45 PM
rear shocks stumpy1 SV Talk, Tuning & Tweaking 2 06-06-06 09:16 PM
Not shocks again !!!! chutz SV Talk, Tuning & Tweaking 15 05-03-05 08:59 AM
