10-10-12, 09:24 AM | #1 |
Pointy cutting out and speedo random numbers.
Ridin today the bike went mental what can it be?
Speedo jumping to 186 and bike turning off! Wouldnt start again then randomly did. Help!!! |
10-10-12, 10:17 AM | #2 |
Re: Cutting out and random numbers HELP
Sure I've seen someone post something similar, Reg/Rec issue maybe?
10-10-12, 10:19 AM | #3 |
When it turns itself off does everything go off i.e. like it's got no battery?
Easy stuff first - check the battery connections are clean and tight. It might be as simple as that. If not, you're on to checking the battery and charging system are in good condition, checking the loom for damage and the connectors for corrosion. Some pointy models have suffered from shorting in the green ignition connector at the front of the bike. |
10-10-12, 10:29 AM | #4 | |
Don't forget the main fuse and connector and live terminals on the relay too.
10-10-12, 10:30 AM | #5 |
Loose battery connection also can cause this.
10-10-12, 10:51 AM | #6 |
There's an echo in here...
10-10-12, 03:53 PM | #7 |
Modern motorcycles are bloody brilliant, enjoy it while we can |
SV650S-K3 Speedo failed (random numbers) - Rotor seems OK, speedo drive problem? | Tallguy | SV Talk, Tuning & Tweaking | 4 | 25-05-12 12:38 PM |
Pointy restricted ECU part numbers? | k1ngy SV | SV Talk, Tuning & Tweaking | 5 | 09-04-12 06:35 PM |
Pointy speedo random numbers? | Badeye | Bikes - Talk & Issues | 19 | 17-03-12 08:15 PM |
random numbers generator or not? | Spider | SV Talk, Tuning & Tweaking | 2 | 18-09-09 10:31 AM |
My Speedo, aka The Random Number Generator? | dode74 | SV Talk, Tuning & Tweaking | 7 | 29-07-09 07:49 PM |
