Old 21-08-16, 03:48 PM   #1
aj76
Default Spark plug change and arrow on lead
Hi Orgers,
Was looking into the rough running I have been having recently so decided to check the plugs and coils. All was ok with both but I seem to remember reading something about the arrow on the spark plug boot needing to point to the exhaust side.
When I checked the front the arrow was to the opposite side and the leas didn't appear long enough to have it face the correct way so is this something that's critical?
Cheers,
AJ
Sent from my C6903 using Tapatalk
aj76 is offline   Reply With Quote
Old 21-08-16, 04:56 PM   #2
Craig380
Default Re: Spark plug change and arrow on lead
It's possible the spark plug caps and boots have swapped previously. As long as the cap fully engages onto the top of the plug, and the plug lead isn't snagging or stretched across something, it should be fine.
Old 22-08-16, 10:21 PM   #3
You can spin the rubber bung around on the plug cap if needed.
Spark plug change? rapidgaz Bikes - Talk & Issues 5 02-09-14 08:05 PM
Coolant and spark plug change on K9 - how? lordra Bikes - Talk & Issues 37 12-06-13 06:31 AM
Spark plug change - how? SV-net SV Talk, Tuning & Tweaking 21 11-05-13 04:08 PM
Can a loose spark plug lead cause this? thefallenangel SV Talk, Tuning & Tweaking 11 14-10-08 08:09 PM
Spark plug change, now misfiring. butterick99 SV Talk, Tuning & Tweaking 18 09-06-08 07:22 AM
