Old 20-03-17, 03:43 PM   #21
bathwiggle
Default Re: Biking and Rheumatoid Arthritis
Originally Posted by embee View Post
Apologies to all, this is an SV site, but if your issues don't improve consider a Honda NC with the DCT transmission. I have a NC700 DCT and have to say it is a brilliant bit of kit for anyone with hand/wrist issues, or if you can't use your left foot for gearchanges. The NC700/750 isn't light but carries the weight very low so is a lot easier to man-handle that the weight might suggest. As long as you can use the front brake it should be fine.
I'll bear that in mind, Thank-you
Originally Posted by Red Herring View Post
Fitting a quick shifter would get rid of at least half the clutch applications......
Perhaps on a more serious note I'd be more concerned with right hand brake application. There really isn't much room for limited capability in that department.
This is my concern and why I'm asking to seeing can make it easier. Most of the time with the sv and planning the engine breaking is fine, but because or the pain that'd why I've not ridden as it's not worth the risk if I can't solve the issues.
Originally Posted by Exuptoy View Post
It looks like there is a hydraulic clutch modification available of the SV. Should make the clutch lighter.
Good luck with it. .
Ooo thank you ill have a look at that
Old 20-03-17, 07:38 PM   #22
Read this thread BW, http://forums.sv650.org/showthread.php?t=63498
There is a cheap solution to a lighter clutch if you still need it, and less complicated than swapping to a hydraulic system. I'd try getting the clutch cable system serviced, so its working 100%, and the use this device if you're still having problems
http://www.smproducts.co.uk/details/...easy-lightener
Old 20-03-17, 10:13 PM   #23
punyXpress
punyXpress's Avatar
You haven't got a 'shorty' lever fitted have you?
Now: Street Triple R
Old 21-03-17, 11:55 AM   #24
R1ffR4ff
R1ffR4ff's Avatar
I suffer from RA in some fingers and fitting fatter gel grips has helped a lot over the years,
I've fitted a set to my SV but had to sand off the ridge on the throttle sleeve and take the end caps off the grips(To allow for bar-end weights).The larger diameter and gel helps stop vibrations and fatigue through my fingers.Unfortunately I cannot find this style any more on eBay or Amazon.
However I suspect these would be a good replacement,
http://www.ebay.co.uk/itm/7-8-1-22Mm...kAAOSw~otWg2sJ
Also I'm looking into fitting my,"Vista" cruise control but will need to replace the throttle sleeve,
http://www.jaws-motorcycles.co.uk/bird2.htm#vcc
They seem expensive for a small piece of plastic and a few metal bits but they are excellent and worth the money.Unlike,"Cramp Buster" paddles you can't hit it accidentally and on long clear roads/Motorways it's great relief.
HTH
Old 21-03-17, 12:56 PM   #25
NTECUK
NTECUK's Avatar
If you get to see the old crew at the 8 ball now empire.
Jump on my Tiger and see if it's very light action is your cup of tea.
The streets and Daytona are as light too. I have rubbed some of my Axsain on my hands on bad day's.
Though my main concern is the knees
Old 21-03-17, 07:00 PM   #26
bathwiggle
I'll have look, brilliant, thank you
I dont, currently the bike is stock apart from the rear shock.
HTH
Thankyou, i'll add it to the list of things to try!
The problem is im still in luton, although if i have the bike i'm more likely to try and visit them due to the traffic, but last time i tried any distance i just couldnt do it, i've not even made it to the dunstable meets for a year now.
So far i've got the bike out of the garage and managed to start it.... then my hands got cold so i came back into the warm.
Old 21-03-17, 07:05 PM   #27
R1ffR4ff
R1ffR4ff's Avatar
I also have Keis heated inner gloves for the cold.Heated inners or gloves may help?
Old 21-03-17, 07:28 PM   #28
bathwiggle
I have a heated vest, i was looking at the gloves but havent been to try any yet
Old 21-03-17, 07:33 PM   #29
R1ffR4ff
R1ffR4ff's Avatar
Any pain I get increases with the cold so the Keis heated inners are great.It meant I could keep my old Gloves but I always buy one size bigger to allow for inner gloves
Old 21-03-17, 07:42 PM   #30
bathwiggle
I'll add that to my shopping list!
New to Biking Nugget1975 Bikes - Talk & Issues 17 18-09-12 07:26 PM
Secondary Arthritis dizzyblonde Idle Banter 23 30-04-08 06:08 PM
New to biking!! krhall SV Talk, Tuning & Tweaking 18 14-11-06 08:03 PM
My Biking Day. Peter Henry Bikes - Talk & Issues 8 11-09-06 09:45 AM
Am I going off biking? Mervin Bikes - Talk & Issues 33 10-02-06 01:49 PM
